Adelaide Nitro ON-ROAD
#138
Paul is the Skyline pipe you bought a vr12s??? Are you happy with it? did it bend in the land speed record attempt?
#139
guess wat i finally took the g4s for its maiden voyage today at lh and had a blast, struggled alot with the 1 way but its somthing to get adapted to i guess, took it easy just putted around but need some help to stop gettin the rear to stop sliding around but apart from that im very happy with it
#140
Originally Posted by Kodak Hodak
Hey All,
Question: What ride height you all running for ya On Road - Nitro's? Looking under my car i placed
$0.70 cents = 9mm on the front
$0.90 cents = 11mm on the rear
i found this tip as i dont have a height gauge and this was the next best thing!!!
a.Do you a for racing, shift the location of the shocker tower?
b. remove spacers
c. change springs
cheers for help........
b. remove spacers
c. change springs
B Remove or refit the spacers to achieve the height of 40 cents (5mm) any higher and it will traction roll on foam tyres always push the car down and release it before checking ride height.
C i dont think springs are available so your only option is to make what you got work properly i rekon go 40 weight oil and if it still rolls stiffen up the sway bars moving them in 1mm at time start from the rear first. Too much on the front and you will lose your steering
Set your camber at about 2-3 degrees negative at the rear and 1-2 degrees neg at the front set your front wheels to toe out 1 degree
If you dont have any measuring tools set a straight edge up against the wheel and assume 1 degree = 1mm it will get you close
Drive it for a while and check your tyre wear if it is scrubbing the inside reduce camber a bit idealy you want your tyre to wear out evenly giving you the biggest contact patch on the track
Good luck let me know how you get on
#141
#143
for sure u dont realise it until its gone but im up for the challenge wat do u guys recomend i should do to get more grip cos i was just so taily wen u apply the throttle out of a corner
#144
#147
Hi. Im moving down from Tville in Nth QLD to Adelaide and am hoping to live near the little Hampton track. How many nitro 1/10 run? , who can i contact to join the club down there and get some info and finally, I own the new RRR Evo WC edition and was wondering if anyone else down there have one and what is a good setup for the track. The setup i got on my RRR is for our tight and low grip track up here.
Cheers
Ray
Cheers
Ray
#148
Not set up in the world will stop you car doing a 180 when you hit your brakes
with a one way , you have to change your driving style nothing to to do
with grip levels.
What a one way does is give you better off power turning.
#150
Cheers
Ray
Cheers
Ray
http://www.rrcsa.org.au/
