2WDrivers Series
#31
I think the idea of a feeder class for 1/12 is ok but i found when i started racing 1/12 with a 10.5 i could not get around the track well .as soon as i bolted in 5.5 turn in boom more downforce more grip more fun and easier to drive.
its been said before but if spec 1/12 comes in wont it dilute the class ,as it isn't raced much across Australia no Victorians and only a few fast south Australians.
if it aint broken don't fix it
It's the new people we want to race 17.5. It will generate numbers long term because there will actually be people acquainted with 12th looking to move up at some point. So we gain them rather than having to poach people from TC and offroad.
Edit: it could dilute the class if you make the spec class too fast like 10.5, but 17.5 would be slow enough that it won't be an issue.
#33
Exactly!
People say 1/12th in the country comes and goes in waves, and they are right, but the reason that happens is because there is no feeder class. We have to attract racers from other classes who have little idea about pan cars to begin with. It would be a huge help if they were learning about their cars in a genuine initiate's class.
Rollout for a 17.5 should be around 100 mm or a little more, I've heard of people going as high as 120 mm, which sounds stupid, but there apparently aren't any issues.
12th scale needs to be split into 2 classes of racing. Traditional for those that want to run it, and a spec category.
The spec category needs to be controlled to a certain degree, spec a speedy and motor combination, the rest is open, ie tyres and bodies.
The spec category needs to be affordable to run and a feeder class. More importantly it needs to be a feeder class into RC racing. From there racers can then take themselves into the other area's of electic or gas racing.
When I started racing in 1984, you either raced 12th scale or 8th scale gas, very simple, 2 choices.
At the time my father indicated that he would not be "bank rolling" any of those activites and I got a job mowing lawns, washing cars after school and thats how I entered the racing world....
My point is it I could afford to do it at a young age, I must have raced for the whole season on $200 after setup.
Ask yourselves this question, how many young kids/familys are you seeing racing these days? Not many, and entering into electic TC's these days even at stock level is expensive and complex.
A 12th scale feeder class is a perfect, cost effective platform to allow people to enter the world of RC racing....
Best of luck with the series, its great to see and a big thanks should go to Badman for having the initiave to get it up and running.
Regards
Kyle
#34
I'll add to Kyle's post..
A feeder class.needs to be speed and.power limited (aka 540 silvercan). This allows a less.than perfect racer to come to grips with the driving aspect much quicker. Also limited speeds provide closer racing and.allow newbies.to be.closer to the front of the pack.sooner. This all.helps in keeping people interested in running the class. How.would you feel jumping into 12th mod and being lapped 15 times each.run. People get.sick of this real quick.
#35
On the weekend the car running 17.5 had a best lap of 17.6 s in the final, managing 24 laps. Compare that to the first A final where Bradd did 34 laps with a best of 13.3 s. The ultimate pace of Stock is probably a bit quicker than 17.6 s, but for comparison that time is mid-field in the Mini A.
But anyway, basically we all agree this is something that needs to happen. I'm working on my club members, and am now going to try and initiate a class on club days. If you guys could get one or two to nominate too, we can get the class kicked-off here. Offer a spare car to someone if you can. If this doesn't launch at the first attempt we should keep trying, but hopefully we can get it off the ground.
#36
Sorry for the confusion but I was using the 540 silvercan "TC" class as an example. I agree with 17.5.
BTW using brads time as the benchmark, low 14's would be possible with a 17.5 but far easier to drive.
#37
#38
#39
I think you're being a bit optimistic. Grant's average lap time to finish 2nd was a 14.6, so if you could do low 14s consistently you'd have finished 2nd! The car running a 13.5 fully timed in the B final had a best time of 15.469, I don't think you could go much quicker than that with a 17.5 under the same conditions.
#40
#42
