SpeedyRC AARCMCC EP On Road Queensland Title 13th to 15th April, 2018
#91
Just to clarify the rules for the event for the demo class - Tamiya Racing Trucks:
1. Legal kits: Item 58632 RC Team Hahn Racing MAN TGS (TT-01 type E chassis) & Item 58642 RC Team Reinert Racing MAN TGS (TT-01 type E chassis)
2. The kit must be built exactly per the instruction manual.
3. The ONLY Hop-Up Options are
Ball bearings (any type/brand)
Alloy Prop Shaft set #54026
Alloy Prop Shaft part #53620
4. Must use stock pinion and spur gear (61t spur/19t pinion)
5. The kit Tamiya TBLE-02S ESC and kit supplied motor (item 54358 RS-540 Torque-
Tuned Motor) must be used. Battery connector may be changed to DEANS or other type. Motor Bullet connectors may not be removed.
6. All body parts must be used.
7. Body may be painted in any scheme.
8. Must use kit tires and wheels. NO tire treatment allowed.
9. Any grease or lube may be used to lubricate gears or moving parts.
10. Batteries: Any round-case 2S LiPo battery or Nimh (6 cells)
may be used for this class - voltage check applies.
Local Rule: NO motor treatment of any kind allowed at the track premises.
Please let me know if you wish to have anything else answered.
Thanks,
Leonard.
Thanks,
Leonard.
Few more questions:
Alloy prop shaft - i've got one but it's Yeah racing branded is this a no-go?
I didnt use the Tamiya servo saver and used one from another car, is this ok?
Can i mount a fan to the car?
Thanks!
Karl.
#92
The optional parts to be used for the event must be as per rules listed (or use kit parts). So the Yeah Racing one won't be allowed for the event. The kit servo saver needs to be used.
Fan is fine.
Sorry if it sounds harsh, but the class has a ruleset that has been established for the event. Hope this clarifies the class.
Thanks,
Leonard.
#95
14 Days
until it's party time in Brisvegas
#96
7 Days...
Getting close now!!
Getting close now!!
#97
Driving down from NQ this is going to be epic
Mega Trucks and some other car things
#98
Track CLOSED as of Monday, 9th April
Hi all,
As per event rules (AARCMCC rule 6.2.5), the track is CLOSED from Monday until Friday morning (when open practice commences).
Anyone found practicing during this time will be disqualified from the event and no refunds will be given.
The track is also CLOSED to ALL CLUB members with keys (regardless if they are competing at the event).
Thanks,
Leonard.
Thanks,
Leonard.
#99
Friday Practice
Please don't forget that Friday is the practice day. There will be 2 rounds of controlled practice by classes at the end of the day
At the end of the last controlled practice round, the track will be open until 9pm.
The controlled practice rounds will be used to seed the qualifiers. The fastest 3 consecutive laps method will be used.
- round 1 starting around 3pm
- round 2 starting at 6pm (under full lights - for all)
#100
Just a reminder to all racers this weekend, please make sure your equipment meets the current rules. (i.e. bodies/esc/esc firmware/lipos/motors approved by ROAR/BRCA/IFMAR for your respective classes).
It is the RACER'S responsibility to ensure your equipment meets the rule set being applied (as per AARCMCC rules Jan 2018 edition).
Thanks,
Leonard.
Thanks,
Leonard.
