Go Back  R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Mystery Spline Screw >
Old 06-16-2017 | 10:01 AM
Questions?? Mystery Spline Screw
I am looking for the screw size for the servo screw that goes into the Hitec C1 metal spline.
I have been looking for days now, and can’t find one.
Firstly, I made an assumption that all C1 metal splines are the same. I’m not sure if that is true, so I will give you the specific servo I need the screw for.
The servo I need the screw for is an HS-82MG
I have found through research that the screw that comes with that servo appears to be a metric screw. Specifically, a M2.3 X 5mm screw. I couldn’t find any information on the thread pitch.
I couldn’t check it, because I could not find any M2.3 screws of any size anywhere to compare it to.
I need that same screw, but 2mm longer. So it would be a M2.3 X 7mm screw I am guessing.
Do these exist? I am mounting a custom part on the spline that has roughly a 2mm thickness after being pressed down over the spline.
I have searched online and found every manufacturer of metric screws that I could, and they all think I’m crazy when I say it’s an M2.3 screw. They say they would have to custom manufacture that for me.
Before I am forced to go that expensive route, I want to first absolutely confirm the actual screw size and find out if I can get the parts that I need from HiTec or their distributors.
I do business with Servocity.com, but they were unable to find me the longer screws. I am almost positive I had seen them on their website quite a while ago, but I can’t find them now.
If anyone out there has had a similar issue, please tell me what your solution was.
HalloweenBob is offline
