Go Back  R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Lynx 3D radio or receiver problem >
Old 12-17-2001 | 12:04 PM
Default Lynx 3D radio or receiver problem
I was racing with my Lynx 3D radio and suddenly it just went nuts. I tried it again and it had steering but no throttle. So I tried a two different speed contols and the same thing. Then I tried a different radio with the same two speed controls and they both worked fine. I was just wondering if I could get the mailing address to the service department or somewheres to get it fixed.
Thank You
Sparky 1822 is offline
Old 12-17-2001 | 12:59 PM
TSR6's Avatar
RCTech Member #2
Did you change crystalls or are you using the spectra?
Try a different channel or module see if that helps.
From the Hitec Site:
TSR6 is offline
Old 12-17-2001 | 03:35 PM
Tres's Avatar
Company Representative
Also check your motor...
A motor can cause the same issues as you describe....
If not:
goto:
www.hitecrcd.com for warranty info
Hope this helps....
Tres is offline
Old 12-17-2001 | 03:37 PM
Thanks for the help. I tried all the things but still nothing, so hopefully they can figure it out.
Old 12-17-2001 | 03:55 PM
Tres's Avatar
swap your plugs around on the RX from 1 to 2 & 2 to 1......
the problem should reverse and you have motor but no servo...
Tres is offline
Old 12-17-2001 | 09:21 PM
To me it sounds like a Rx problem. Try what Tres has suggested to eliminate the Rx from the equation. If you find that the Rx is gone send it in and we'll get it fixed up for you. TTYL.
Gary F.
Gary Fliegel is offline
Old 12-18-2001 | 08:51 AM
There was other problem that I had with it. I put the radio in my 1/8 scale gas buggy and everything worked fine except when I started the engine. I would go wide-open and turn all the way left. Then when we turned off the engine it would be fine. So I don't know what was with that. But I will send it in. Thanks again.
Old 12-18-2001 | 09:29 AM
Tres's Avatar
sounds like a loose connection in the Rx......
if anything is loose on a gas car where metal it touching metal, it will cause RF noise and that will be picked up by the Rx....
slightly wiggle the plugs with the motor off and see if it still has issues....
to be safe, I would send it in....
hope this helps......
Tres is offline
