5925 not centering
Old 02-18-2003 | 12:55 PM
Default 5925 not centering
I have a 5925 that I have been running in 1/10 buggy. The last time I raced I noticed that the servo seemed to center incorrectly. I would trim it out on the radio and it would seem fine until the next heat. Then it would be off center the opposite direction. I would trim it out and be fine until the next heat. In the main I had the same problem but then it decided to recenter during the race. I compensated by holding the wheel over a tad to keep it going straight for the rest of the race.
My question is this: Is this a known problem? I don't want to send it in to be repaired and have it sent back marked no problem. I can try to keep running it but it kind of sucks to have to hold the wheel off center to go straight half way through a race.
windellmc is offline
Old 02-18-2003 | 06:46 PM
Company Representative
Do you have the correct horn on the servo? It has to be a 24 tooth spline otherwise it will pop from one side to another and cause what your describing.
Gary
Gary Fliegel is offline
Old 02-19-2003 | 06:26 AM
It is the Associated one that comes in the B3 kit for a Hitec. What is strange is that it will be fine until I turn the car off and back on again. Then it is off center.
Old 02-19-2003 | 04:01 PM
What kind of radio are you using?
Old 02-20-2003 | 05:57 AM
Ko Mars R. I haven't had any problems with other servos with this radio.
Old 02-20-2003 | 06:23 AM
Tres's Avatar
What is the date on the side of the servo?
Tres is offline
Old 02-22-2003 | 07:31 PM
Tres's Avatar
I had one of the guys at the track tonight with the exact same issue..
Mars radio, servo not centering....(non-Hitec)
Not saying this will cure yours, but he tried another radio and all the issues went away....
We swapped servo, Rx's, ESC...
After all that we tried another radio....
No everything works fine with all original equipment except radio..
Tres is offline
Old 02-23-2003 | 07:25 AM
The servo is dated March 2002. I don't think its the radio since it centers fine with an Airtronics servo.
Old 02-23-2003 | 04:57 PM
Tres's Avatar
With that date code, you shouldn't be effected by the "DATE CODE" issue..
Tres is offline
Old 02-24-2003 | 12:51 PM
So should I send it in or wait for it to get worse before sending it in?
Old 02-24-2003 | 12:56 PM
Tres's Avatar
I would send it in....
contact: [email protected]
There is also warranty info on the HITEC site.
Tres is offline
Old 03-02-2003 | 01:11 AM
Tag's Avatar
Tag
hi there, i have the same problem, but my seems worse than the gentleman above. i have a 625MG installed on my buggy and it does the same thing not centering, i have the correct servo horn and gears seem fine no stripped gear are found. it just wouldn't go straight. by the way, i use a Jr R-1 radio. Do i have to send in for repair ? about how much it will cost me? i don't have the receipt can i still claim the warranty ?
thank you,
Jeff
Tag is offline
Old 03-02-2003 | 06:10 PM
What kind of buggy is it in?
Old 03-04-2003 | 06:22 PM
Tag's Avatar
Tag
Hi, i actully have 2 625 servos, one installed on my mugen mbx4 xr and another one in my v one r..both are dead now..
i am planning to send them in but i would like to know if i can still claim warranty if i lost my receipt.
thanks
Tag is offline
Old 03-04-2003 | 06:44 PM
Yes, just explain that in the letter when you send them in. TTYL.
Gary
