Ask Team Tekin
#572
Jeff we can Josh close in no time... I have a normal base we put in new cars that gets a good start for stock 1/12th... From there we will have to work driving style roll out to lock in the motor.
#574
No oval Saturday.. Only once a month but we may have myself or jess in Saturday night for a bit and open up... Should know by tomorrow night... Jess can get home really close also... Friday night we can get a base setup in also....
#575
M11x with 451r in high response mode
Can you tell me if i should be using the normal or HRS mode with my tekin RS, which by the way i have been super pleased with?
#576
17.5 Redline Rotor Question
I'm looking to replace the rotor in my 18 month old 17.5 Redline. I'll be running 1/12th scale spec, "blinky", no boost, would you recommend the 12.3 or 12.5 mm rotor?
What is the performance and/or feel difference between the 12.3 and 12.5 mm rotor ROAR legal?
Thank you.
Thank you.
#577
Thank you.
Thank you.
12.5 more torque
http://www.teamtekin.com/blmotors.html#redlines
#578
#579
When running 1S 1/12th scale, is there an advantage in running one rotor over the other?
I see other motor manufacturers offering 1S rotors and they seem to have a smaller diameter.
I guess I should be asking what is a 1S motor? Is the Tekin motor a good 1S motor?
#580
Run the 12.5, it'll slow you down.
#581
question on the tekin RS. is there a limit on the amount of times you can solder on the posts?
i replaced my battery wires once, and in the next couple of days im going to replace my capacitor on my tekin rs as well add a 1s booster, to which ill have to remove my battery wires again off the posts... i know if i have the iron on too long, it can damage it, but i make sure i let it cool and work quickly....
#583
#584
#585
