Ask Team Tekin
#1321
Well I use an x-tronic 4010-pro-x but honestly after thinking about it quite a bit, I believe it might be me, I mean Tekin has competent engineers for sure but I may use the wrong tip and too high temps, etc. I also have a miniware ts-100 that I haven't opened yet. I appreciate your input for sure, thanks!
#1322
Hi,
What's the size of the tip you are using, It needs to be quite large to keep the heat. I would usually use a tip around 5mm for speedos and motors.
Personally I've found the new Tekin solder posts easier, quicker to tin the solder post, the solder on the wire.
If you can try a larger tip, it will have more heat (thermal mass) so better when you put the wire / solder post / iron tip together.
MiCk B. :-)
MiCk B. :-)
#1323
Question, anyone hasve trouble with paramters using Tekin Hotwire 3.0 BT?
i was working with Rs Pro BE, and i noted, when the changes were made by app, the parameters dont hold on esc or dont work properly, but when i use the interface pc, works normally the changes
anyone had this problem? I´m using android 13
#1324
This is the cheap iron I bought for home use, to share tips with the MPS (gen1, the gen2 is just as good) I travel with. Pair either with a T15-D52 tip, and there isn't an RC power connection I've had any issues with up to 10ga. If you order genuine Hakko tips, shipping is free when you get 3 or more, and you get to avoid the big list of DOA complaints you see in Amazon reviews on the T12 knock-offs.
Hi,
MiCk B. :-)
MiCk B. :-)
Contact area comes into play as well, which is where a bigger tip helps, but again, a bigger/heavier tip alone isn't the whole story.
#1325
I have found also that the app drops the bluetooth connection pretty often, so you also need to make sure the HW3 is showing the proper LED lights showing that it's staying connected so you can make your changes and apply properly.
When I do all of that, I haven't seen any difference in settings applied to the ESC from my phone or a PC.
Hope that helps.
#1326
Is a Tekin RS (The original one from about 10+ years ago), still a viable ESC with Brushless motors of today? It appears the new Tekin Hotwire stuff wont support this ESC anymore, but maybe I am misunderstanding their website.
Thanks!
Thanks!
#1327
I have to ask a dumb question to start: Are you hitting apply in the app after making changes, and does it pop up the dialog as it's writing?
Hope that helps.
Hope that helps.
- apply changes, hit drive, connect again, read the parameters. sometimes show the parameters that i changed sometimes not
- apply changes, hit the click the connect/disconnect button
- turn off and after turn on and read the parameters
- made downgrade from 291 to 258
After many test with HW, i tried with PC, and worked all the changes, after setup the esc on PC and work, i tried again with HW and happened again, the same thing
#1328
Yep, still gets the job done. All of my original RS's eventually died, and I updated via the non-warranty repair/replace option through Tekin, but they did just fine up until they didn't. In just about every case, the sensors stopped being read. Not upset about it, they were used for years, then sat unused for 8 years, then lasted another year to year and a half of competition before I had to start sending them in one at a time.
#1329
its not a dumb question some really forgot to apply the changes, i made some tests:
For mod motors, are you trying boost in sensored only mode, or in dual drive? Using the C1 or C2 profiles, or built in?
#1330
[QUOTE=HarryLeach;15973861
For mod motors, are you trying boost in sensored only mode, or in dual drive? Using the C1 or C2 profiles, or built in?[/QUOTE]
- Sensored only
- C1 Profile but i tested also the others profiles
if is possible, can you make the same test, using HW BT, input a mod profile (can be lowest values just for test) and note if the parameters really works or sometimes seems was a blinky mode
#1331
The main "problem" if the parameters really works on esc, for me using the HW BT didnt work, only using PC
- Sensored only
#1332
#1333
We have a new ultra strong rotor coming out for our SpecR motors that will increase the torque. Overall the SpecR motors are a higher kv design for flowing tracks and need to be geared a little lower than most other motors. For a short high grip track with tight layout I hate to admit it may not be the best choice. We will see with the new rotors.
#1334
#1335
Tech Legend
- High Torque Silver rotor
- telfon shims they include in the box
- Ceramic bearings
- 45 - 49 degrees of timing on can
I have also had some good luck degreasing the bearings and re-lubing with a light bearing oil like SHAG bearing oil as some felt like they had some really heavy grease in there.
