Like Tree55Likes
TT-01 Forum
Old 01-06-2010, 01:38 AM
  #1726
soonboon's Avatar
Talking
Hello , Where do you all play ??
i playing tt01
soonboon is offline
Old 01-07-2010, 10:07 PM
  #1727
mytto1's Avatar
hey guys.
just curious, wat do you guys think bout my tto1
oh and i had that p7 ball issue too. replaced the ball. i was the one at that one past weekend i think stichy lent me a p7 ball," thanks sticthy you saved my day)
mytto1 is offline
Old 01-08-2010, 01:54 AM
  #1728
rough512's Avatar
Trader Rating: 12 (100%+)
to those using the 3racing conversion kit, did the conversion eliminate the propeller shaft wobble?
rough512 is offline
Old 01-08-2010, 04:53 PM
  #1729
Default which brushless?
hi all. i'm building up a tt-01r and needed help with which brushless system to get. i'm not gonna be racing this thing, just parking lot bashing. I've been doing some research and noticed that a lot of people are running the ezrun combo. I was originally gonna go with the novak havoc system, but had read all sorts of horror stories on this forum. I am looking for something comparable to a modified stock brushed motor (19t i believe). I've been told that the 13t brushless is equivalent. So which system should i get? the 13t ezrun combo or the 13.5t ezrun combo? OR if there is any other brushless systems you'd recommend, that'd be great. My budget is around 150. Thanks in advance!
atrain62 is offline
Old 01-08-2010, 06:09 PM
  #1730
MD
MD's Avatar
Trader Rating: 136 (100%+)
Take a look at the ezrun systems on Nitrorcx.com. Their prices are good.
MD is offline
Old 01-08-2010, 07:35 PM
  #1731
get the 13.5t for sure, you'll wanna get the systems with .5 because they have full 540 rotors rather than 380. more torque. i am VERY happy with my system. hey mytt01, whats with the different tyres on each side?
i just got a castle sidewinder system 4600kv, very quick, but the brake and the drag brake are seriously poor, i don't have a PC, only mac, so i am unable to update it.
cydog510 is offline
Old 01-09-2010, 01:11 PM
  #1732
mytto1's Avatar
oh i just swapped out one side of the car to my dish wheels. and how come you didnt get the novak gtb spec or pro? i have the 8.5 and man that thing flies. what i do is on my transmitter i have a epa setting(end point adjustment). max is 140% which is the full potential of my 8.5 and if i just tone it down to 115% it is equivalent to a 10.5(im just guessing) but what im trying to say is that i can make my 8.5 go as fast as a 10.5 13.5 or a 17.5. i like doing that becuase when i race i always turn it down to a 10.5. im not sure if you or anyone else likes to do that but i really like that setting. oh and the braking on the gtb is great!!
mytto1 is offline
Old 01-16-2010, 05:39 PM
  #1733
Starteur's Avatar
Does anyone have a decent set-up for a TT01 type E ?
I just bought a TT01R type E and wanted a baseline set-up to start.
It will have a 27 turns motor.
Starteur is offline
Old 01-16-2010, 06:43 PM
  #1734
pyrodon's Avatar
I have a question i just want to know if the 3racing m chassis makes the tt01 have a smaller wheel base?
pyrodon is offline
Old 01-18-2010, 07:23 AM
  #1735
rough512's Avatar
Yes, shorter and narrower than the stock 1:10 TT01. About the same width as the Tamiya Mini.
rough512 is offline
Old 01-19-2010, 04:16 AM
  #1736
knd
Do you know if the Tamiya Mini Bodies fit? Need any adaptation?
knd is offline
Old 01-24-2010, 04:17 AM
  #1737
Starteur's Avatar
Anyone??????
Starteur is offline
Old 01-24-2010, 07:28 AM
  #1738
MD
MD's Avatar
Starteur - I ran my TT01E all summer in parking lot races with the 25/55 gear ratio, Tamiya yellow springs all around, HPI X-pattern pro compound tires, Tamiya plastic oil shocks ( I'll have to check my notes for the oil I used), the shock position in the front was the inside position, and the shock position in the rear was the outside position. It handled very well. The X-pattern pro's were great.
MD is offline
Old 01-24-2010, 02:42 PM
  #1739
UrabusDenis's Avatar
A question about LIPO conversion
A friend of mine suggests that I cut the "ribs" of the place where the battery would go (to flat it out).He says that the vibrations caused by those ribs could damage the battery. I have a normal 7,4 LIPO (not hardcase)
Do you think this is necessary?
UrabusDenis is offline
Old 01-24-2010, 03:37 PM
  #1740
dfiantii's Avatar
Trader Rating: 18 (100%+)
That's a new one never heard that before..
dfiantii is offline
