Tamiya TB-Evolution III
#3721
Originally posted by V12
Yes Steen Graversen´s drivetrain is the best you could think of. When I saw it at the Euros I wished I could buy it from him. But no chance.
From what I have heard his father was working with real racing cars in the past so he know´s what he´s doing!
As a sidenote from what I have heard at the SD the oneway gear also breaks from time to time as the driveshaft is a little bit too long so it can´t shift enough in a heavy crash.
But I must add that Steen has been working on two cars. The newest one has the entire yoko SD driveshaftsystem+diffs integrated. And it is absolutly wonderful! It drives so freely you won't believe it.
But before that he worked really hard on the original tamiya drivetrain, and he actually managed to get it to run almost as freely. His father fixed some of the drag, by drilling slightly bigger holes in the gearhousing, perfektly lined up over eachother, and added some alu. rings around the ball bearings, to fill out the gab. But rember this is no simple task, they have to be exactly line up, or else the drivetrain will bend at the first run you make.
But he sold it to one of my clubmates about two weeks ago, so he is really depending on his yoko SD/evo3 design.
Take care
SSL
#3722
No offense meant but if Steen is going so far as to run a complete Yoke drivetrain.....why isn't he just using the Yoke SD car !!!!???? Anybody have some more positive things we can do with the Tamiya drivetrain !!??
What ever happened to the idea of using metal gears?? Are they no longer available....anywhere??
Let's start something new....If you could help design the Evo4 drivetrain..what would you do??? be specific...you never know who might be paying attention.
#3723
Shimming as previously described by others will help minimise the damage to the gears, at least it has worked for me in minor crashes.
#3724
Re: BigDogRacing
Originally posted by High-Speed
BigDogRacing,
Are you the Jason that put the smack down in the 19t TC class last month in Atlanta with the Evo III S at TFB?
BigDogRacing,
Looking forward to coming back to Hotlanta with you guys!
#3725
#3726
Re: Re: BigDogRacing
Originally posted by BigDogRacing
Uhhh, yea that's me Kenny. Good to see you here!! How's your EVO3S runing? Did you get it to stop eating pinions? Gotta stay off those boards!!!! lol
I ended up shimming the back end of the drive shaft to bring it up forward and to take the play out, so it would stop sliding back. Tested it with about 4 packs and Seems to be working so far. Headed to TFB tomorrow for more testing and much needed practice.
Thanks for the help that weekend too.
#3727
Hey Guys, I used the gear support last sunday that my friend machined for me. 5 practice runs + 3 heats and a main....the gear looked new at the end of the day. Like I said this isn't a 100% fix, but it will help. If you would like to see pictures of it, go to my original post:
http://www.rctech.net/forum/showthre...pagenumber=116
or page 116 of this thread
If you don't know anyone that can machine it for you, I can get them done....cost will be about 16 or 17 shipped in the US. Outside the US? Not sure on shipping.
Ej
I'll test it again this weekend.
Oh also, for those racing TCS, it's not legal
Ej
#3728
cool! Looks good. So the Tamiya drivers use almost the same thing on their one ways huh. That support looks similar to the one on the one-way that that VIC posted. Its worth a try.
#3729
Originally posted by PizzaDude
coop,
Go to a bicycle store and buy White Lightning (dry wax).
That should work.
coop,
That should work.
Any specific way to apply it/break it in?
Coop
#3730
Ej
Ej
Did you get one for me too???? If it works so well why did you come in 6th Maybe it's rotating mass is like a fly wheel and accelerates too slow!. or was it the Redline Motor??
Piznal
#3731
Hi all,
I was wondering, Is the One-way issue something that happens to some cars and not others?? I have run my Evo III SL several times and had some hard hits both front on, and side on with no One-way gear problems yet.
If it IS a problem that only affects every other car it would seem that mine has escaped the curse. So far so good any way..
steevo
steevo
#3732
skill & patience when assembling the drivetrain. It just can't be
thrown together and expected to simply work/last.
Have inherited some chewed gears in my stash, also a whole ton
of new ones. With the same 5 gearboxes (2 of which would have
chewed those gears), I've built them "carefully" & been running
them for many months now... still not yet killed a gear yet.
Heehee... my e3+Orange drivetrain is so free, when I place it on
the track, the thing starts rolling away just from the teeny
weeny gentle slope (otherwise undetectable) of the land.
#3733
Originally posted by forty6
So jfc_tech is just dreaming all this???
ok...thats my 5 cents. no harm done..happy racing. peace to all.
#3735
Originally posted by Randman
Got my first raceday with the Evo 3 today, went through a 1 way gear, but no other parts broken. Got some tips from Rocketron at the track though, so hopefully I wont be going through any more gears
