Engine stalls without the glow starter ??!....
Ok sorry for all the questions guys....but after being able to start the engine....
i found that once i take the glow starter out the engine just stalls....
ive searched for topics like this but i just cant find it ??!
the engine stalls if i just leve it to neutral for a while...
ive tried adjusting the needle valve and things etc..
any help would be very much appreciated
thank you
thank you
It might due to defective plug. The plug is damage.
get a new glow plug, that's a typical symptom
Could be engine is too rich and/or idle speed is too low.
Lean the mixture by one more turn and increase idle by another 15 or 30 min turn.
thank you
thank you
Ok, it all depends on how new or old the engine is. If you rev it up and it takes too long to spool up then it is too rich. On the other hand if it revs fast then bogs and sounds like it's gonna quit, then it's too lean. Like others stated, it could be your idle it wont hurt to raise it up as long as the clutch doesn't engage. If the motor is in the process of being broken in then this type of behavior is somewhat normal. If the engine has more than two gallons through it, then a new piston/sleave might be needed. Good luck!
