Advance R/C Car R10 2015
#991
Franko,
Looks like the new and approved Petit RC is up and going again!
Link to IIC setup. http://www.petitrc.com/reglages/arc/...Vegas20141018/
This is a good starting spot for long shocks. Maybe add 1.3 rear bar and go to 2.5 deg of rear toe.
For short shocks I'd start with Xray 2.5-2.8 front spring and Xray 2.6 rear spring. Also 1.3 rear bar and 3.5 rear/rear block to make 2.5 deg rear toe.
Then on the front blocks I'd go with the 3 split and 3 solid with -75 hexes and tune from there.
Hope that helps.
Kody
Hope that helps.
Kody
#992
Franko,
Hope that helps.
Kody
Hope that helps.
Kody
#993
hi all...if anyone in australia is after a new arc15 with options and spares.....i have this for sale..........could post worldwide if required for a bit extra
thanks for looking
David
http://www.rctech.net/forum/australi...l#post14198344
thanks for looking
David
#994
Received my Avid Aluminum chassis today. looks nice! i did notice a discrepancy with the FR (rear)suspension holes. The holes are spaced to wide to accept the designated rear separate suspension arm holders. Looks like Avid made the holes to match the RF suspension arm holders. So to sum it up, looks like i need another(front) set of front rear suspension holders to mount the rear up. ill have to compare geometry differences with the variance.
#995
#998
Good to know, thanks Minh. Any idea what they will do for the people that bought the old version? With my wide setup I have a feeling my droop screws will destroy the edge of my chassis over time...
Nm, just read hobby-squares Facebook post. They are going to replace them all.
Good info on it here:
https://www.facebook.com/hobbysquareusa?fref=nf
#999
Can I use the 64p gears for mod or should I go with 48p?
#1000
I think it might work just fine for my 2013...BR Jerry
#1001
Decided to pull my car off the shelf. It's been sitting there since The Reedy race with a blown dcj. Fixed that and set the chassis up. I hit the local asphalt track today to knock off some rust. Man it feels good to drive again. The R10 handled great! It was just a practice session and I needed to cycle batteries. But the car was flawless. I did install the new Floating system with zero issues. Ran pack after pack with good pace and consistent times. Cant wait to actually race again.
#1002
Arc R10 2015
Hi to all, as the Arc R10 2015 is the first rc car that I have to assemble,I need a little help.
I started to assemble the car and when I arrived to the spur I noticed on the instruction manual its show that the three screws have to be near each other. And here is my question, because my logic tells that the screws have to be in separated with an empty hole. ( screw - empty hole - screw - empty hole- screw and empty hole).
Any help is appriciated and thank you.
I try to attached some photo with the spur how i think to suppost be assembled. And under the part there is the image how shows the manual, which in my oppinoin there is a mistake.
Thanks again
dont know if the picts were attached
Thanks again
#1003
Thanks again
Thanks again
#1004
Arc R10 2016 new update
2016 approaches very soon any info on any updates for our Arc R10.
