Like Tree164Likes
Tamiya TB Evo 6
Old 10-10-2015, 07:53 PM
  #1111
Emaculant's Avatar
Trader Rating: 11 (100%+)
What spur brands and sizes fit?
Emaculant is offline
Old 10-10-2015, 10:23 PM
  #1112
clint's Avatar
Trader Rating: 24 (100%+)
I went with ARC cnc 76t 64p spur on my EXO-5
clint is offline
Old 10-11-2015, 03:56 AM
  #1113
Trader Rating: 8 (90%+)
I used Robinson Racing Super Spur 75t
TenzoR is offline
Old 10-11-2015, 06:52 AM
  #1114
theproffesor's Avatar
Trader Rating: 66 (100%+)
I also went with arc. 74 and 76 tooth. I messed up and got 84 tooth the first time, but you can't fit a 84 tooth spur with a 56 tooth pinion.
theproffesor is offline
Old 10-11-2015, 08:52 AM
  #1115
Emaculant's Avatar
Thanks!
Old 10-11-2015, 01:35 PM
  #1116
rtypec's Avatar
Default Exo 6 Photos
I found a few pics from last month's ROAR Nationals and have attached them for your viewing leisure...enjoy!
rtypec is offline
Old 10-11-2015, 02:51 PM
  #1117
Hat has everyone been doing about the chubs made of glass. I broke 4 left fronts l. 2 in 17.5, and 2 in GT. About to start my main in GT and going to run with a broken one because I used all my spares.
Other than that this car is on point. The setup I put on it when I built them was a great starting point. Only minor RC and a spring tweaking to do. This car responds really well to set up changes.
Old 10-11-2015, 03:32 PM
  #1118
Square do some excellent alloy c-hubs but they are 5 degrees. Else just use the 417 parts as they are stronger but you will need different shims etc
Qatmix is offline
Old 10-11-2015, 03:55 PM
  #1119
rtypec's Avatar
You can also use non carbon reinforced plastic chubs as well.
rtypec is offline
Old 10-11-2015, 05:32 PM
  #1120
What's the part numbers on the 417 parts or the non carbon reinforced parts?
Old 10-11-2015, 05:55 PM
  #1121
CL
CL's Avatar
Trader Rating: 34 (100%+)
http://www.tqrcracing.com/shop/produ...w.asp?p_id=585
CL is offline
Old 10-11-2015, 06:26 PM
  #1122
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Rtypec....that car is sweet. Looking forward to getting mine.
Josh-n-ya is offline
Old 10-11-2015, 06:29 PM
  #1123
Emaculant's Avatar
What spring set to purchase I have the black edition? I run on medium to high grip carpet.
Old 10-11-2015, 06:51 PM
  #1124
I run the RSD carpet spring set.
Old 10-11-2015, 07:15 PM
  #1125
JimmyMac's Avatar
Only way I could reliably run my 418 on carpet with CRC ClikTrak was with the Square Aluminum chubs. All other brands are too thin and bent very easily. The Square ones are much more robust. The ones I used were the older style aluminum ones that needs slight modification to work with the double cardan axles. They were 4 degree, but are super hard to find now. Here's the mod I did and the clearance.
You might can find the 5 degree ones easier, but not sure if you would like the handling? I dunno, never had a set.
JimmyMac is offline
