STOCK motor forum
#2131
Isnt Motor Spray the same thing as Brake cleaner, IE the one with Hexane's as the main ingredient?
vortex: no, they are actually different.
#2133
Thanks Todd.
#2134
whats a good stock motor for stock racing and racing with freinds.
#2135
Don't we all race with "friends"?
#2136
I have been having an overheating issue with Monsters on really hot days of 90 degrees plus.
Is there another stock motor that handles that kind of heat better?
Thanks.
Thanks.
#2137
Well, if you don't mind alittle less power and more difficult tuning, the Orion or Reedy stocks have the better FB9 magnets....so they won't suffer from the fade you see in the trinity stocks, which use the cheap wet press magnets.
You should just buy a Much More Motor cooler or use the ice trick.....start the motor out cooler and it won't have problems on those hot days....in fact, any day they are worth using.
Later EddieO
Later EddieO
#2138
Thanks Eddie. Long time no hear...Good to hear from you again.
But, you have now taken over the title of "Is it here yet?" with your website...I keep checking...he, he...
#2139
ok so i dont know how to tune a motor. and i am looking for a VERY low maintinance motor that will run powerfull AND fast.
any ideas
any ideas
#2140
Later EddieO
Later EddieO
Sean
#2141
Originally Posted by Team Duratrax
So if you want a longer lasting motor you must sacrifice some power because of the FB9s?
Sean
Sean
#2142
Originally Posted by micros_rock
Uh, that's what he said didn't he? Unless I just can't read.
Sean
#2143
The FB9 is actually a more powerful magnet than you will get in a trinity stock.....but, because they are so powerful, they actually over power the armature. At some races, when they were the handout, we actually had to take them to a propane torch to demagnetize them some....these magnets are really meant for modified motors
The MVP/Hellfire is also VERY tricky to tune.....numerous tweaks need to be done to the hoods along with the brushes needing to be cut down on both sides.
On the dyno, the MVP will max out around 97 watts at 20 amps and 118-120 at 28 amps.......while a monster will be 100+ and 125+....and on the track, the monster blows it away in most classes......however, on the local scene....I highly doubt 7 watts will be the difference between first and second, its gonna come down to driver and car setup.....
Later EddieO
Later EddieO
#2145
The Binary stockers had quad magnets, and were epoxy-balanced. Both of those are illegal by current ROAR rules. The rules call for 2 magnets and a drill-balanced armature.
