Serpent 960....
#781
Originally Posted by going4#1
UAlthough the car had little punch with the standard clutch settings, it had very good speed over a longer stretch and was able to out run most other competitors.
C Verano, i know you said you tried the Blitz no.2 high speed body, pity it made the car too loose. Did you leave the rear body mount settings standard for that shell? Have you tried the newest no.3 body yet?
#782
#783
i run with blitz 530 since last year and i have no problem,the rear is ok...
i think they used this body at Messina...
#784
Originally Posted by C Verano
Good job on your first time out. What gearing are you using in first gear? If you are using the stock pinion and spur,you can get some extra rip out the corner by using either a 15-49 or a 16-50.
The next race is on a big track though so I may need to change strategies again. The track is big enough to run out of fuel in less than 5 minutes. Looks like I'll need another 2031.
#785
#786
Hmm yeah as far as i know Collari used the no.3 Blitz body there. obviously worked for him
I'm using Kawahara now and it's not bad. I'm looking to try Kyosho as well. I'll need to test all 5 on one day to find the best one for me though. Finding a best all-round body is tough since the car's driving characteristics change as the tires get smaller.
I think if you're looking for the best body, testing multiple makes is probably the best strategy since handling often depends on driver preference and skill. I would test on the same day so conditions match as equally as possible. Fast bodies tend to be sensitive and require very delicate steering inputs. You can make very fast direction changes but the car is less forgiving and it requires more concentration. High traction bodies tend to understeer and are more forgiving (i.e. rear tends not to swing out) but you need to turn earlier to compensate for the added stability.
#787
so going4#1 how is the kawahara body is it a high down force or a netrul body . and what type of track are you testing on .
#788
bodies
I keep things pretty simple with the bodies. I always bring the Serpent EV3 and a Protoform Lola to the track. I always start off with an EV3 Lola and if I need less steering I switch to the Protoform.
#789
Hmm cool, sounds good. Granted i havent driven with serpent long but the ev3 is the only shell ive run on it so far. Good to know that, thanks C Verano.
#790
#791
What does everyone else use for a wing? Mugen is good but expensive. Looking for a cheaper but equally effective alternative.
#792
#793
The body has more steering than the Protoform but not a huge amount more. Down force is good but I'd give it a neutral rating. The biggest difference with PF is it tends to crack less. On the downside, no stickers, no wing (I use the Mugen wing), and no stiffeners. It is cheaper than the PF in this area (US$23.00).
#794
#795
ha chris how are the handling with the short wheel base do you the evo3 with that set up?
