Mugen MTX-3
Originally posted by highwayman
... why is a diff better for a small track, as compared to a 1-way? wouldn't a 1-way provide more steering, entering and exiting as compared with a diff?
Originally posted by czotalis
mabey because on a small tight track you might need to hit the breaks alot (tight turns, avoiding someone that spunout or crashed bofore you)
Tried diff and didn't like it.
I tried the front diff with the oil that comes with the kit and didn't like it at all. It gave me understeer off-throttle going into corners, not to mention the snap-oversteer coming out of hairpin corners. It was really bad. I went back to the 1-way as it was over half a second faster per lap. Maybe the diff would work better if I chased the set-up a little, but I did not have time, as we were getting ready to start racing a short while later. I also tried a heavier oil (30,000) with the 1-way and it was slower- more oversteer off-throttle into corners. The traction was poor however. I also use drag brake to get the car to turn in better. I would call the driving style required to go fast in my car as smooth into the corner, aggressive on throttle out of the corner-Kind of like an 1/8 car.
How to certain the piston is not at Top dead center while breaking in the engine.
Hi guys,
I am going to get a Novarossi 5 port engine and i had this exact prolbem before during break-in period. Piston stucked at the top dead center and i can't turn the flywheel and i need to used heat gun on every startup in break-in period. (it is pain )
Becasue i am going to get a new engine and will do that again. Can someone tell me how do i certain and tell the piston is not at Top dead center while the engine is cooling down for another tank? What will you do if the piston is at top dead center? heat gun or ?
Thanks.
Thanks.
I had been using the 1 way, then put my locked diff in for the smaller (heheh ) Florida tracks. Then one lazy day I left it in for my home track and I've searched out and built a front diff. You can accelerate harder and longer then slam on the brakes for the turn.
Originally posted by Fire
i think it's just a personal preference, if throttle after every single coner then of course brake is needed to slow down b4 the next coner, so an oneway will not work
Can someone tell me what color of front/rear spring for good traction?
Harder spirng for good traction
Softer for loose traction ?
Thanks.
Thanks.
Thanks.
Thanks.
We have a medium to large size local track.
I am running stock gear 47/43 and 20/16.
What is the best combination gear for good low/top end if running in medium to large size track?
Thanks.
Thanks.
Hi guys,
I ordered a R40 a week ago and I just realize there's a new 2004 version comming out I am new with on road and I currently own a RS4 Evo. Should I just sell the R40 and pratice with my RS4? Needless to say I will have to spend lots of $$$ to make it run. (very broke at moment) I might get into racing when I have better skill
How does the current R40 stock compare with MTX-3 with the same engine, mainfold, pipe, servos, etc???? I am asking because there's more MTX-3 parts than R40 locally.
Please help me out guys...
Lower arm position
What will they do?
A-A
B-B
C-C
A-A
B-B
C-C
Originally posted by nero1943
Hi guys,
Hi guys,
Dish the RS4 away!!! (unless you drive like Hara, you can win with any car like RS4!!)
So get yourself that Mugen!
Trader Rating: 27 (100%+)
Originally posted by TitaniumR
How also will a NS12 JP compare against a NS15S5? Inputs appreciated. Thanks.
