Mugen MTX-3
Old 06-24-2005, 03:36 AM
  #15406
Originally Posted by cdelong
get the cvd's for the front- that's pretty much the only fix for your situation. as for the rear, i place small pieces of fuel tubing in the rear outdrives and in the axles to keep the dogbone centered.
performula is offline
Old 06-24-2005, 04:06 AM
  #15407
asw7576's Avatar
I think I'm all set ( thank you AFM and Robbie ).
The car is doing very well today, no oversteer and no understeer !!! it's just perfect. Entry corner speed is good ( off throttle ) as well as accelerating corners ( on throttle ). I can hold my racing line and even take somebody's racing line
Sometimes I get traction roll but you can blame it to bad tires choice. I'm checking tommorow weather outlook in Jakarta:
Saturday : 50% chance of raining, cloudy all day, 82F
Sunday : 30% chance of raining, morning cloudy and sunshine in afternoon, 88F
Okay!! I'm ready !!!
asw7576 is offline
Old 06-24-2005, 10:34 AM
  #15408
Derby Bros Racing's Avatar
good luck asw!!!
Derby Bros Racing is offline
Old 06-24-2005, 07:17 PM
  #15409
Fsturbo15's Avatar
Originally Posted by tazman34685
I just noticed that both the FR and RR width of the car is lower than 200mm. Will a narrow wheel width affect handling? I know the FR dog pop out often in the Front while turning. I have tried to be the FR and the RR to 200mm but the dog bines are an issue. I need help
Mine is also less than 200 mm.
I would like an answer to this as well.
I'm around 194mm I THINK
Fsturbo15 is offline
Old 06-24-2005, 08:57 PM
  #15410
Slotmachine's Avatar
Talking Track width
Less track width should provide you with more corner speed and more traction. This will also make the car a little less stable, but I always run the front less then 200mm.
Slotmachine is offline
Old 06-24-2005, 09:31 PM
  #15411
Fsturbo15's Avatar
Thanks man.
My car is stable right now.
It has to much traction though, the car sticks to the pavment to much for my taste.
If I loosen the pivot balls up and make it around 198, the car will loose some traction right/
Old 06-26-2005, 03:57 PM
  #15412
Bandeira's Avatar
Hello Guys...
I'm havin problems making 5 minute quals with all of my engines... Anybody tried those extra venturis that have less inner diameter? My tank is making 4:45 minutes and I needed it to about 5:20... Which one should I get? do Hety make 5.3? 5.2? Do they scrub much power?
another issue, my car seem to be quite dialed on turns... But on race some other drivers... seem to take the turns faster... my car seem to lack in speed while turning... If I increase my dual rate, the rear end would come happily...
I was thinking of reducing track width... as mentioned before...what else can I do? I'm using Monotuning Tyres... I may change for some 2mmOffset ones like fast or so, then the roll center would be changed, in benefit of turn speed... What else you guys think I can do?
thanks in advance...
Sorry of da Long post...
Bandeira is offline
Old 06-26-2005, 10:52 PM
  #15413
evild's Avatar
FOR SALE: BRAND NEW MUGEN SEIKI MTX-3 PROSPEC
Mugen Seiki MTX-3 Prospec with O.S. 12TZ 3-port and MSR .12 Competition Pipe (P01002) for US$700.00
This car has NEVER seen pavement. The engine and pipe HAVE NOT tasted fuel.
More details in the For Sale/Trade forum thread: http://www.rctech.net/forum/showthre...21#post1665721
evild is offline
Old 06-27-2005, 12:21 AM
  #15414
asw7576's Avatar
Originally Posted by Bandeira
Hello Guys...
Entry corner speed problem ? Try lighter oil like 40w first try, 50w second try.
Small diameter Venturi ? They scrub power but increase fuel economy.
asw7576 is offline
Old 06-27-2005, 08:03 AM
  #15415
BigBadJabba's Avatar
hi guys, whats the largest capacity battery i can buy for my mtx3? or recommend me a place to get them cheap
BigBadJabba is offline
Old 06-27-2005, 08:24 AM
  #15416
gonzoY5's Avatar
AAA packs are the only ones that will fit on the car in its intended position. You can get 1000mAh batteries at this place http://www.thomas-distributing.com/ap-1000-2.htm
These are the highest capacity I've seen, but I haven't tried them.
gonzoY5 is offline
Old 06-27-2005, 09:30 AM
  #15417
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Got to batteries pluss. They built me a 1000mah nm-hi pack for $22.00. I also took a some Sanyo industrial batteries and stacked them to give me a better pack of 1350mah. They are Sanyo Twicell HF-A1U batteries. They look like a stack of PEZ candies and they take all the space that is available under the fuel tank area but I don't have to worry about a long main.
rcfoolz is offline
Old 06-27-2005, 01:07 PM
  #15418
Bandeira's Avatar
I'm using the Mugen 600oil... I sould try something lighter...]But apart from that, any other suggestions?
I know that... I just wanted to know if anybody tested that and if they scrub too much power...
Bandeira is offline
Old 06-27-2005, 03:59 PM
  #15419
Fsturbo15's Avatar
Hello Guys...
Thats an easy fix.
I have the Mugen X-12 and it is known for poor fuel economy.
I reccomend getting a very long fuel line from the gas tank to the engine, longest you can get.
After that, purchase a good fuel filter.
This will get you to about 7-8 min.
Old 06-27-2005, 04:59 PM
  #15420
Bandeira's Avatar
Thats an easy fix.
I've already had probelms with low pressure because of the long fuel line... But... I plan to race on sanctioned events... So, my tank and fuel line must be 75ml....
Bandeira is offline
