F201
#76
Originally posted by MYXTYPLYX
Dragon Slayer- Nice video! Any more?
psycho- 3000 might be good. Let us know how good it works.
19 turn spec looks like the wave of the future. Lets get it off to a good start by using it exlusively in our F201.
Also for the remainder of the on road out door schedual I hope to run this car a few more times as I have only run two packs thru it.
#77
Originally posted by Masato
Hello F201 Fans,
Have any of you noticed the new High Performance F201 kit w/original body listed at Tower Hobbies? Has anyone seen this kit in thier LHS?
I was waiting to purchase the F201 untill this kit came out because of the two bodies and the supposed lower price of 3000yen/$20-25US. (Shizuoka Hobby Show New Items Release)
Insted, the kit is being sold for $20 more than the original kit.
Oh well, I guess I waited for nothing. Time for me to place my order with my LHS for the Ferrari kit!
Late,
Brad "Masato" Murata
Hello F201 Fans,
Late,
#78
I'm a bit curious about this car, so could someone tell me a few things:
The car is pretty cheap, so does it have ball bearings?
Will saddle packs fits?
Is there a chassis for saddle packs?
Will the drivetrain take the power of the most powerfull motors?
Thanks!
BR/ JesseT
Thanks!
BR/ JesseT
#79
jesseT: yes, the car has ball bearings. the stock chassis only accepts stick packs. im not sure if you can fit side by side packs if you use a dremel on the chassis, but i think ive heard someone try it. there is an aftermarket carbon fiber chassis, but i dont think its for saddle packs. the stock gear ratio is fixed because of a non-adjustable motor mount, im not sure what is the fastest motor that can make use of the existing gear ratio. but from what i read down the thread, theyre using 19T motor with great success.
#80
Yes I know about the motor and surely it has to be changed. Does anyone know about a chassis that accepts side by side packs? Are you all running stick packs?
BR/ JesseT
BR/ JesseT
#81
There are two problems with using anything other than stickpacks on the F201. The forst is with the kit chassis. There are plastic spacer thingies that hold the stick pack in place. 30 minutes of Dremel work will take care of that. The real problem is because of the "battery cups." They are rounded and provide rigidity on the right side, so you can't really Dremel them to make side-by-sides fit. These cups are also where the body posts mount to, so if you chop them up, you have no place to mount the body. I have the Cross chassis (sorry DS, I didn't get time to take pix.) It would fit side-by-sides easily if it weren't for the battery cups. I plan on making a plate that the body posts can mount to so I can get rid of the battery cups. This should also make a solid place to glass tape the battery to. I'll let you know if this is going to work.
#82
To All-I just wanted to let everyone know that Schumacher USA is the Distributor for the Cross and Take Off F201 Hopups.
We have Take Off Color Screw kits in all colors in stocl now.
We have all of the Cross Hops Ups in stock except fot the carbon chassis kits (we only ordered a few and they went fast). The Carbon chassis kits seem expensive but you get 2 chassis plates and a ton of gold alloy standoffs and bearing blocks.
Item No. Mfc. Description US Retail
CTF-07 Cross Aluminum Center Shaft, F201 $35.99
CTF-1 Cross Carbon Chassis Upper Deck Set, F201 $119.99
CTF-10A Cross Bearing Set A, F201 $59.99
CTF-10B Cross Bearing Set B, F201 $38.99
CTF-120 Cross Aluminum Motor Mount, F201 $44.99
CTF-130 Cross Titanium Rear Torque Rod Linkage Set, F201 $15.99
CTF-15R Cross Carbon Rear Dumper Stay for CTF-1, F201 $25.99
CTF-19 Cross Titanium Steering Linkage set, F201 $15.99
CTF-20 Cross Spur Gear Holder, F201 $12.99
CTF-23 Cross Titanium Push Rod Set, F201 $19.99
CTF-6H Cross Hard Spring Set, F201 $9.99
CTF-6M Cross Medium Spring Set, F201 $9.99
TS634B Take Off Color Screw Set: for F201 Blue $54.99
TS634BK Take Off Color Screw Set: for F201 Black $54.99
TS634G Take Off Color Screw Set: for F201 Gold $54.99
TS634P Take Off Color Screw Set: for F201 Purple $54.99
TS634PK Take Off Color Screw Set: for F201 Pink $54.99
TS634R Take Off Color Screw Set: for F201 Red $54.99
#86
Originally posted by big al
..... and man talk about a pristine comm. I barely skimmed it and it was ready to go.....The stock gearing seems pretty close to perfect?
#90
Hi Guys,
We are also carrying F201 parts on our website now
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Steve Wang
Speed Tech R/C
www.speedtechrc.com
