Kyosho Touring Car >
Kyosho Touring Car
Kyosho Touring Car
Old 04-21-2008, 05:44 PM
  #1771
quiksilver611's Avatar
I believe the car is Kyosho TF-5. It was a orange,white and black car with a dodge stratus body. It was a 1/10 car with a 20 turn motor. A guy at my hobby shop has a friend that worked for rc car magazine and did a review on this car. When he was done he sent to him because they knew eachother and he put it up for sale. It wasn't even out yet and he was selling a $379 car for $200. I saw the car on display and thought it was good deal and almost bought it but I am an offroad racing fan. He later took it off the sale and kept it. Put a 19 turn motor in it to run with the 19T class.
This is no lie i sware on my grave its true and the car new car you are talking about is probably this one. You can see pictures of it on kyoshos website.
quiksilver611 is offline
Old 04-22-2008, 02:15 AM
  #1772
TRF415boy's Avatar
Originally Posted by Joe Maxey
That was it. It cracked the fiber where the two halves meet.
Thanks a million.
I thought it might be, i had the exact same thing happen on my first race with the car, now I'm carrying spare top decks...
TRF415boy is offline
Old 04-22-2008, 02:34 AM
  #1773
SuperEk4's Avatar
Trader Rating: 32 (100%+)
I believed you r talking abt the rtr TF-5? shaft driven? I m looking for the belt driven Hirosaka's edition.
SuperEk4 is offline
Old 04-22-2008, 07:51 AM
  #1774
alana07's Avatar
Trader Rating: 53 (100%+)
why dont you go ask masaki's young protege nicholas? you can meet him every weekend at our local track....
alana07 is offline
Old 04-23-2008, 08:34 AM
  #1775
SuperEk4's Avatar
I asked before he dunno leh. I ask Alexander he finally told me it cost 3 times of a pro kit.Because he personally service the car. i finally give up. The cost is too much.
SuperEk4 is offline
Old 04-24-2008, 07:46 AM
  #1776
ON A MISSION's Avatar
Trader Rating: 34 (100%+)
Default car
Welll after running the car last night for the first time , i would have to say it works really well for my first on road car . i know somebody posted it before but looking for a front steel spool or something better than the plastic one's , i had to put in the one way after i found the pipe a few times any idea's
ON A MISSION is offline
Old 04-24-2008, 01:41 PM
  #1777
I)arkness's Avatar
try and get the delrin spool they seem to be very tough, might take some looking around to find one on the net but i have seen them for the kysoho shin and stallion version just cant remember where
I)arkness is offline
Old 04-24-2008, 01:53 PM
  #1778
Aaron Waldron's Avatar
I don't mean to stick my nose into someone else's business, but I do want to clear this up. I reviewed the Kyosho TF-5 Readyset with the orange, white, and black Dodge Stratus body for RC Car Magazine. We do not sell any of our cars, nor do we authorize the sale of any products given to our magazine. After our testing of the TF-5 Readyset was complete, the car was given to a friend by an employee as a gift, about two months after the car had been tested. Obviously it's out of our control by that point, but I must clarify that we do not sell our test cars or products.
Aaron Waldron is offline
Old 04-24-2008, 01:55 PM
  #1779
GMartinez's Avatar
Trader Rating: 91 (100%+)
you can try [url]www.speedtechrc.com
GMartinez is offline
Old 04-24-2008, 10:57 PM
  #1780
Default st
anyone with parts or car for sale lmk looking for tf-5 stallion parts
Old 05-03-2008, 03:17 PM
  #1781
32819toon's Avatar
Default SHIN EDITION
Is the SHIN edition a complete rolling chassis kit, or just the carbon fibre parts ?
32819toon is offline
Old 05-03-2008, 03:32 PM
  #1782
TRF415boy's Avatar
There's a rolling chassis and a conversion kit.
Old 05-06-2008, 03:19 AM
  #1783
32819toon's Avatar
Default tyres
can you run 26mm tyres on a TF5 or must they be 24mm ?
Old 05-08-2008, 10:08 AM
  #1784
Default car
Originally Posted by King of B Main
Guys here is Derek Furantani setup for High bite to medium bite asphalt...Great starting point , and pretty sure it will work for the shin car. I have used this setup for stock, and 19 turn brushless...
Front of Car
Spool or One way with AA diffs
Front block CCin , 2 mm spacer in front hidge pin, #3 spacer underneath blk
Rear block CCin , 1 mm spacer in rear hidge pin, #3 spacer underneath blk
Droop 5 with yokomo gauge
Camber 1.5 to 2 degree camber you choose, toe 0 to .5
Stock 3 hole pistons, 45wt kyosho oil, blue kyosho spring(I use Tamiya gray)
2 mm spacer in Front top camberlink, use the back camber link hole
Shock position 2nd hole from bottom
Rear of Car
Front block BBin, 2 mm spacer in front hidge pin, #3 spacer underneath blk
Rear block DD out, 1 mm spacer in rear hidge pin, #3 spacer underneath blk
Droop 4 with yokomo gauge
Camber 2 ( I look at ware of tire, I usely use 1 degree)
1 mm spacer in rear top camberlink in far back hole
stock 3 hole pistons, 40wt kyosho oil, orange kyosho spring(I use tamiya blue)
Total 3 degree toe
Shock position in middle of shock tower
AA rear diffs
We use Mazda 6 or Mazda speed 6 bodies
Tires RP30 out door or Sorex 36 with yokomo thin insert at Socal
Hopefully this will be a good starting point and I did not forget anything..
wow !!!put this set up on my stallion . night and day from what i was running . now looking for another stallion to set up for stock lmk
Old 05-08-2008, 10:13 AM
  #1785
Default set up
are those the tamiya short blue springs or ?????? b main
