Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 09-25-2005, 02:01 AM
  #1396
We run on rubber, and it isn't bad to be honest, I fitted a pair of braces from the gearboxes to the chassis to remove that little bit of flex there. As for it being a porker, it is, there is no way of getting round it, on GP33's the car is well over a 100grammes overweight, and no matter what, that is a lot of extra weight to cary round a flat track.
On carpet though, it is very good, but I ran my chassis stiffer than stock.
DA_cookie_monst is offline
Old 09-25-2005, 05:56 AM
  #1397
bighurt98's Avatar
Trader Rating: 11 (100%+)
Default TA05 Overweight?
I was thinking about purchasing a TA05 and you have now got me thinking.
What is the minimum weight for sedans?
What is actual weight of TA05?
Is there any places to save weight?
Thanks!
bighurt98 is offline
Old 09-25-2005, 06:14 AM
  #1398
In the UK, minimum weight is 1500grammes, all up including shell at the moment is 1610grammes
Old 09-25-2005, 06:18 AM
  #1399
cheehtae's Avatar
Trader Rating: 15 (100%+)
does any body know what the part# for the Tamiya Turnbuckle ( hop-up) to use on the TA05? The stock ones just keep stripping , all the help will be appreciated, and also for the steering rod too. One more thing will the 6mm. alloy hub be an OK fit ? I've been using spacers in the front because we only raced carpet and most of my wheels are 28mm. If you can see in the picture the front ball cup is almost touching the wheel.
cheehtae is offline
Old 09-25-2005, 08:42 AM
  #1400
MobileIT's Avatar
Originally Posted by cheehtae
does any body know what the part# for the Tamiya Turnbuckle ( hop-up) to use on the TA05? The stock ones just keep stripping , all the help will be appreciated, and also for the steering rod too. . . . .
I do not know the number, but it probably will not help. The option parts are probably just lighter weight versions of what you have now. Measure how much of the rods are in the ends and see if you have enough room for longer rods, and then, if you have room, buy the longer rods individually.
That depends on the rest of your wheels and tires, suspension and who is measuring your car. The legal limit is 190 mm for *everything.* Most cars I have seen are actually illegal, but the officials will sometimes overlook it if the wheels and tires are within bounds. If you use narrow suspension blocks, and you are not using much camber or toe-in/out, then the hubs can generally be wider. Using 0 offset Kyosho wheels and Shimizu tires with the factory setup (as per the manual) and 5mm hubs, my front is 188 mm, but my back is 189 mm. So in theory, I could put 6 mm in the front, but I would rather have some leeway to change my camber or toe-in settings later. Actually, even if I did use 6mm hubs in the front I do not expect I would be able to tell the difference in handling anyway.
MobileIT is offline
Old 09-25-2005, 05:00 PM
  #1401
Smile TCS Question's
Hey all.
I just bought the TA05 with the Mercedes boby (ony one at hobby shop)
Everything's going smooth I just have a question about the TCS rules on body choices.
I plan to run the Mercedes body for the first few runs while I shop for a new body. I was wondering if I can run the TA04 Corvette body on the 05 and be legal. Also when not running at a TCS track I'm thinking of the Stratus 3.0 or the new Pontiac G6 body. I've herd alot of good thing's about the Stratus but no one has the G6 yet so if anyone out there has the G6 i'd like to here what you think.
And finally....anyone go Brushless yet?
Crypt_Keeper is offline
Old 09-25-2005, 09:08 PM
  #1402
kenny's Avatar
"And finally....anyone go Brushless yet?"
I did. And some others on here have too! Here is mine! Novak SS Plus/5800.
Attached Thumbnails Tamiya TA05 Touring Sedan-dsc02209.jpg   Tamiya TA05 Touring Sedan-dsc02210.jpg
kenny is offline
Old 09-25-2005, 09:31 PM
  #1403
kenny's Avatar
Also,
Does anyone know of an online store that sells replacement and hop-up parts for the TA05?
kenny is offline
Old 09-25-2005, 09:37 PM
  #1404
Thai3g_Eclipse's Avatar
www.speedtechrc.com
Thai3g_Eclipse is offline
Old 09-26-2005, 05:20 AM
  #1405
SPEEDTECH
Hi, I noticed now, you are selling alloy lower gearbox housings for the TA05, something that I have been thinking about, is it possible to make a rear gearbox housing, so the eccentric bearing mouldnings can be fitted up normal, or inverted, this would give two diff heights??
Is it possible?
Old 09-26-2005, 07:58 AM
  #1406
rayhuang's Avatar
Did anyone run the TA05 at Vegas on foam tires?
rayhuang is offline
Old 09-26-2005, 03:27 PM
  #1407
cheehtae's Avatar
Originally Posted by kenny
Also,
Towerhobbies.com
Thercshack.com- you can actually pre-order any parts from them, just give them the part number that you need , they are Illinois base.
cheehtae is offline
Old 09-26-2005, 04:37 PM
  #1408
MobileIT's Avatar
Originally Posted by Crypt_Keeper
. . . Also when not running at a TCS track I'm thinking of the Stratus 3.0 or the new Pontiac G6 body. I've herd alot of good thing's about the Stratus but no one has the G6 yet so if anyone out there has the G6 i'd like to here what you think. . . .
The only videos from the Las Vegas IIC race were pretty unclear but I think I saw at least 1 Pontiac G6 in one race. I expect we will hear more about it soon.
MobileIT is offline
Old 09-26-2005, 07:40 PM
  #1409
Core Creations's Avatar
Trader Rating: 109 (100%+)
Anyone know where the TECHRACING parts can be had?
Core Creations is offline
Old 09-26-2005, 08:02 PM
  #1410
loopedeloop's Avatar
mail order here:
http://translate.google.com/translat...l%3Den%26lr%3D
loopedeloop is offline
