Tamiya TA05 Touring Sedan
#4666
Originally Posted by Difuser
Woo hoo Mike is coming back, be good to see you around the track and Chumps. I'll be coming in for Speedweek on Tuesday. Latest rumor is no Crisp this year though.....
Garber
Garber
Help me out here with a decent starting point setup for the TAO5 I'm running the TCS month end. You the man I know you have a setup somewhere..
Thanks D. -Mike-
#4667
Originally Posted by RCGaryK
That oil's kinda thick, but it all depends on surface and tires. Where are you losing grip, entering, mid, or exit of a corner and which end, front, rear, or both?
#4669
It's both rubber and foams but i can only use foams cause my set of rubber tires is wrecked and my other set is on my backup car. even if i ran rubbers it would still be slippin n slidin.
#4670
Regional Moderator
Originally Posted by MK_Arbiter
I'm running in parking lot races and im using 45 shore speedmind foams. both front and rear lose traction on the exit. it doesnt seem to be the tires' fault because they were clean and still felt like they had perfect traction by feeling it with my hands.
If you want to use foams you may want to try something like 40 shore at the most or even 37 shore.
Other than that, all I can see is that 60wt oil may be a little heavy for parking lot racing.
#4671
Well it's close to an hour main... about 45 minutes... yea... *hangs noob sign around neck*
#4672
Originally Posted by JamesArluck
Not going to nats George?
-James
-James
Will have to practice extra hard for next year though. Japan...here I come!
#4674
My TA05 had perfect grip on my hardwood floors with the 45 shore tires... So why would it slide so much on asphault?
#4676
That was what i was thinking until I drove my TT-01 there. My TT-01 didn't slide at all.
#4678
lay down?
#4680
One very fast TA05
G'Day
I race on an asphalt track in Australia. In summer I use Sorex 28 or Take off 27. In winter with the night air I will be using Sorex 24 for the next few race meets. The track is very slippery at first but after the other classes (including Nitro) the track is swept and the grip is a bit better. the set up is as per the book but I am using TC4 spring (blue and red). I find they are a bit harder than the tamiya ones. For stock I'm using a CO27 Team scream tuned motor with a 75/27. The car is fast. I one season 1 on the Townsville On-Road comp for stock. Season 2 starts this Wednesday.
Has any 1 run a 10x2 motor? What gearing do you think? I was thinking something like 20 - 22. Any info would be great as I want to see a TA05 race in Mod and be very competive.
See YA
See YA
