Like Tree248Likes
Xray XB4 thread
Old 06-27-2015, 01:34 AM
  #8506
HSV427's Avatar
Trader Rating: 30 (97%+)
Has anyone done some back to back testing on the xb4 15 with saddles compared to shorty, since I've had my XB4 i have only ever run it in shorty setup but am very curious to know how much the buggy changes in its handling with one compared to the other, i guess what I'm trying to ask is one better than the other and if its worth giving saddles a go or am i better of staying with the shorty setup, i run on a medium size medium bite track and was wondering if saddles will help or hinder. TIA
HSV427 is offline
Old 06-27-2015, 06:22 AM
  #8507
BentKa's Avatar
We have ran all the setups back to back to compare slipper to center diff., saddles to shorty, 2mm to 3mm, '14 to '15 and we only run shorty today in all conditions
Bent
BentKa is offline
Old 06-27-2015, 08:18 AM
  #8508
Brit_racer's Avatar
Trader Rating: 198 (100%+)
I read and searched through all the post. To convert the XB4 2014 to shorty the only thing I need to buy is the full length upper deck? This seems to simple.
Can you help me please.
Brit_racer is offline
Old 06-27-2015, 08:21 AM
  #8509
Brit_racer's Avatar
here is the part number i think i have to get :XRA361161
Old 06-27-2015, 03:37 PM
  #8510
Trader Rating: 15 (100%+)
There are discussions on this in depth here and on oople.com about this, try a search for 'shorty conversion'.
In short, no, for a 2014 chassis you need to do fairly major surgery on your plastic tub chassis to remove the middle section, flip the motor mount around, drill new holes in your chassis for the mount....
HeavyD99 is offline
Old 06-28-2015, 08:05 AM
  #8511
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Is the aluminum central bulkhead a direct fit for a 13/14 car?
http://www.xray-shop.at/shop/product...qvdrk1d554jes6
Apparently it doesnt work. They should advertise the fact its for the 15 car.
BDRMBULLY is offline
Old 06-28-2015, 01:28 PM
  #8512
Brit_racer's Avatar
Thank you. I did a search but was not having much luck. Well i will stick to saddles if it's that much hassle. Thanks again.
Old 06-28-2015, 02:22 PM
  #8513
BentKa's Avatar
Well….they actually do.
In the release info it's pictured mounted on the '15 version and when you go to the Xray site it says:
Fits: XRAY XB4 2015 Specs
http://www.teamxray.com/teamxray/pro...ral%20Bulkhead
If you are in doubt regarding parts compatibility or specs just go to the Team Xray site and search the part number for the complete info
Bent
BentKa is offline
Old 06-28-2015, 03:53 PM
  #8514
BDRMBULLY's Avatar
Well i bought 2 for me n a buddy for our 14's. . Its 2mm taller. Than 14 stock piece. I gna hack on mine to make it work
Old 06-28-2015, 04:19 PM
  #8515
BentKa's Avatar
Yes they will be different heights due to the '15 not having the plastic "tub chassis" on top of the aluminum chassis.
Just clearance the plastic chassis and it should fit
Bent
BentKa is offline
Old 06-29-2015, 02:54 AM
  #8516
HSV427's Avatar
Well i finally installed the new optional chassis brace and removed the front and rear top deck and all i can say is WOW, the car now has so much more steering, the buggy felt so well balanced and really nimble you can now carry so much more corner speed as mention before it really brings the car to life, at first i was sceptical i mean really how much better can you make an already awesome vehicle better but trust me when i say they have, the car is so much more stable and reacts so well, at no time did the buggy feel loose or unpredictable, i also installed the floating servo mount however I'm not really sold on it, i will have to spend some time testing it as I'm not sure how it works only mounting on one side, what is there to prevent the servo moving and flexing under hard steering, if anyone has experience with the floating servo mount your feedback will be greatly appreciated.
HSV427 is offline
Old 06-29-2015, 03:48 AM
  #8517
Trader Rating: 77 (100%+)
Are you referring to this option part? http://www.teamxray.com/teamxray/pro...62&kategoria=0
Wease is offline
Old 06-29-2015, 04:27 AM
  #8518
HSV427's Avatar
No Im talking about XRAY 366220
HSV427 is offline
Old 06-29-2015, 10:25 AM
  #8519
jmackani's Avatar
Trader Rating: 14 (100%+)
How much did it lower your lap time?
jmackani is offline
Old 06-29-2015, 03:21 PM
  #8520
HSV427's Avatar
I haven't raced it yet as i have only just installed the parts, although i have had it on the track for a test run it feels faster more nimble and much better balanced the rotation in the corners is amazing, as i said it carries so much more corner speed while staying planted, From testing i would have to say the car will be a second or two faster but if its not its still the best option I have ever installed on this buggy.
HSV427 is offline
