Xray XB4 thread
#2101
#2102
Need help. Car bouncing fiercely and really hard to drive. Using default setup for clay, with JC double dees green compound front & rear with AKA red insert.
#2104
The only big thing Iv'e done other than shocks/tires is drop diff oils to 5/3.
#2108
I thought the box setup was pretty plush. Maybe check for pressurization in the shocks ?, drop the oil weight ? Or go with less hole pistons it sounds like you don't need much pack. And this car likes a low ride height. If it's that bumpy lose the aka inserts and go blue medium jc's or open cell. Also those red foams don't fit the double dee very well imo and allow the tire to "squirm" giving a loose feel to me making those soft wide spaced knobs even skatier. Try holeshots with the supplied foams.
But lighter oil and larger piston hole seems worsen the situation - bounce even more.
Just wondering if I should do the opposite thing - thicker oil, smaller piston hole, etc...
What about rebound? Does it help?
#2112
ok, first run last night, car was really good. how do I stop the front shocks leaking from the caps?
tips?
tips?
#2115
where do u get the alloy caps?
