Xray XB4 thread
#1546
#1547
#1548
I finally got my XB4 out on the track and I was surprised at this car how it loves to be pushed hard.
The only thing I found was the rear was a little loose so I might go to 7K rear diff oil to see if that helps could be part of my driving skill or lack of
But overall the car is awesome
What would the second position on the Ackermann do in comparison to the first?
#1549
In Sweden we drive whit slicks tires on carpet, which works very well.
Looks like this:
http://www.youtube.com/watch?feature...&v=RX9N86kUydU
Looks like this:
#1550
what kind of tires (brand) do you use?
do you prepare them with additive?
#1551
The tires are controltires for the Indoor winter Cup we race in, 4WD and 2WD
http://www.buggy-sport.info/index.ph...-go-world-wide
#1552
Here's the 3rd and final leg of the A-finals.
She got a 5th in this last leg and took a 5th combined after 3 finals were run after placing 4,5 and 5
She lost out to 4th place by just 6/10 of a second after getting passed on the finish line in leg #2 of the finals.
Here's the final ranking list after the 3 finals.
Bent
+ YouTube Video | |
Bent
#1554
Besides the electronics the kit is race ready from the box setup. The metal gears are for those that want some ease of mind with their diffs. I've had my rear diff blow out, but it was also leaking and my slipper set too tight. Other than that my rebuilt rear diff doesn't leak anymore and I have had complete success with it for now.
Just make sure to follow all of the preparation steps when building the kit and build your diffs right. I also did the cvd mod with the axial parts.
#1555
#1556
Metal Gears (Parts from NT1)
335081 Alu Differential Pin - Hard Coated
335030 Differential Bevel & Satellite Gear
#1558
There have been a few instances where the pin from the driveshaft had worked it's way through the plastic shield and started tearing through the a arm. According to xray it happens when you don't apply enough of the graphite grease to the joints. I used Axial part #AXI30462 to provide extra protection.
If your kit doesn't come with the upgraded bulkhead make sure you get the free upgrade kit from wherever you bought it from.
#1559
Thanks j0pp3
We are running the TeamSR 4 mm towers and I've made an aluminum brace for the rear of the bulkhead and a carbon brace connecting the 4 screws for the tower and 2 screws for the front part of the bulkhead.
It's built like a tank now and can really take a beating
She just loves her XB4
Bent
Bent
#1560
Here's a crude cell phone pic of the rear brace made out of a piece of 90 degree aluminum angle:
The upper holes are drilled through to use a nut on the back side while the lowers are drilled and tapped for the 3mm hardware.
I'll see if I have a pic of the front brace as well............
Bent
Bent
