Mugen MTX-4
#8192
thanks for the info, ill try get it around that
#8193
Originally Posted by Artificial-I
Im using a AAA hump pack. Im thinking on using the space thats left over to fill with weights. As the full size battery will only be 100g , vs 70g for the hump pack.
I also have lw digital servos which I dont think im going to get rid of , ti pillow balls , full ti screw kit , lw aluminum threaded balls , ti turnbuckles.
Im probably going to swap back to the stock threaded balls cause the ones I have dont have the 3.0mm hex on the other side to aid in tightening them up.
The rest im kinda stumped on what to remove. I really dont want to remove anything. But im looking into heavy weights that I can stick in a few places hopefully.
use a 2/3A pack will give you more weight at teh chassis, maybe move some ti. ball end.
#8194
Weight
RC=Realy_Costly
If you are going to race in a State or National event with in Australia
The Minimum weight with out fuel is 1725 including transponder
As per AARCMCC Technical specifications
#8195
You want to get it the lightest you can. But 1725 is also the weight limit for ROAR Events. Im sure the same elsewhere.
I will try to get my car exactly to that weight. Also I think I found the solution. Tungsten weights. There small and should fit in perfectly.
I would go to the 2/3A flat pack , but thats only 30g and that removes all my space. With the hump pack I can squeeze in possibly another 90grams on top of the 70 , making for 160G of weight at the bottom and middle of the chassis. This should work out well overall and make the car pretty well tuned. I also saw a spot on the car that might be able to use some weight. Im going to see what goes on with some weight checks on a few items. Try to get the balance of weight on the chassis right and then go from there.
#8196
#8197
Tye
#8199
Originally Posted by Car Breaker
I need a new chassis soon, but Mugen is a bit beyong my price, anyone tried Skyline and 3 racing yet ?
3mm or 4mm
Great Quality great price
I have been using the 3mm for over a year now had some Bad accidents
And is still straight as the day I first installed it.
#8200
Originally Posted by chippy
Go the Kawahara
3mm or 4mm
3mm or 4mm
If it cheaper i'm going to buy that.
CB : I'm using 3racing 4mm chassis in my MTX3. ....... so far so good ( going 3 years now ). It has less metal cutting ( light weight opening )...... easier to clean.
#8201
Mugen Stock chassis: $79.00 / CNC 4MM CHASSIS: $84.99 (Nitro House)
Kawahara K-870 MTX-4 chassis PRO - $48.51 (5800 Yen)
http://babelfish.altavista.com/babel...p%2fk.870.html
#8203
#8205
the link does not tell where to buy at all. it is meaningless if I can't get it regardless of the price
Try here http://www.pro-s-futaba.co.jp/e/tuusinhanbai-os.htm
This is where I got mine from and was a bit cheaper than RMD s link price
Hope this helps
