Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 03-25-2014, 09:37 AM
  #10201
Gayosaka's Avatar
Tebo usually uses Losi oil.
Gayosaka is offline
Old 03-25-2014, 11:21 AM
  #10202
cnelson3's Avatar
Trader Rating: 66 (100%+)
anyone having luck with the front kickup block turned around to 30*? I like 29 at the wheels (25+4) but i need my buggy to cruise over the bumps a little more. Anyone know if this will help?
cnelson3 is offline
Old 03-25-2014, 02:02 PM
  #10203
Originally Posted by purple rides
Using stock shafts with, avid axles. cvd pin/coupler or barrel whatever it's called. Kyosho does not sell the parts separately, why they don't is beyond me Is there any other brands that fit? m.i.p, losi, ae, etc or do I have to swap over to the whole mip system? and use there shafts etc. What option are out there? I know this can't be the first time this has come up.
Anybody? Nobody has lost a cvd pin?
purple rides is offline
Old 03-25-2014, 02:21 PM
  #10204
So ready to pull the trigger on a RB6. Coming from a DEX210 that I struggle with lack of steering, everyone else seems to turn tighter and with better corner exit.
Seeing the common setup sheets online it seems the consensus is mid motor. I run on a small-mid indoor clay track with medium traction -- sometimes high.
Is mid motor the way to go with this ride? Is the Tebo WC setup one that I should build from initially? What are the characteristics of MM for the RB6?
DEX210 in mid motor just wasn't popular in the US unless it's high traction clay or carpet, and most are running RM3 at my local clay track. Is the RB6 most efficient in MM.
Thanks for the help. Looking forward to building one soon.
Vincent_Diesel is offline
Old 03-25-2014, 02:44 PM
  #10205
VenturaDC's Avatar
Trader Rating: 32 (100%+)
The rb6 is a beast to drive MM, way better then my dex210.
Personally id start with Tebo's reedy race setup and adjust from there.
One of the tracks I run on is a small indoor clay track and that setup with Super soft handlebars rear and ions up front the car is money.
VenturaDC is offline
Old 03-25-2014, 03:04 PM
  #10206
Thanks Ventura. I've never driven a MM before. Did you have to adjust your driving style?
Old 03-25-2014, 03:53 PM
  #10207
1967rs's Avatar
Trader Rating: 56 (100%+)
I know the MIP and Kyosho barrels and pins for the cvd are not the same size. Sorry I can not be more help.
1967rs is offline
Old 03-25-2014, 10:22 PM
  #10208
What are people recommending, Tebo or Cody King's Reedy Race setup as a starting point?
Kopanas is offline
Old 03-25-2014, 10:24 PM
  #10209
Try both they are equally good. I feel Cody's is a touch more neutral to drive.
Gitsum is offline
Old 03-25-2014, 10:35 PM
  #10210
VenturaDC's Avatar
Yes, I'm not able to hammer the throttle quite as much coming out of the turns but I can carry over all more corner speed so overall I had to learn to drive less point and shoot and more smooth but my lap times show that even tho it may seem slower to me I've gained near a full second a lap.
Old 03-26-2014, 08:39 AM
  #10211
Thanks... I will start with King's and experiment with Tebo's to see how I like it!
Kopanas is offline
Old 03-26-2014, 11:54 AM
  #10212
I mean this in no way as a knock on Cody King but I was very surprised that someone who is known way more as a nitro 8th scale driver came up with such a good indoor clay 10th scale track. Props to him.
CaseyD is offline
Old 03-26-2014, 04:20 PM
  #10213
Trader Rating: 68 (100%+)
The only difference that I see between king's and tebo's setups is that Cody is running 2 deg anti squat and no shims between steering piece
Speedychris22 is offline
Old 03-27-2014, 07:07 AM
  #10214
The stock pistons that come in the rb6 ,are they 5x1.3 or are they something else 5x ?.?? Thnx
blingy is offline
Old 03-27-2014, 08:51 AM
  #10215
Trader Rating: 96 (100%+)
The stock pistons holes have been discussed in detail in this thread, if you search "stock piston hole " size you will probably find it. IMO, for this buggy, the 5 holes do not have enough pack for a track with even medium sized jumps. The Kyosho 4x1.3 are pretty good but I think 2x1.6 are good too. It has been debated that the Kyosho 6 hole pistons have more pack than the 5 hole due to the hole size being more important than the quantity.
Eric Tomczyk is offline
