Yokomo MR4TC-BD
#8266
hello guys
i have 3 questions for you... that i think you can answer..
is there any catalog or anything at the web that i can take a look at Yokomo Pit wear and clothes??
where i can find online aluminum front and rear universals??
and last but not least should we expect a new BD or a new version of the existing BD after the worlds??
thanks in advance
thanks in advance
Yokomo must have a completely new design chassis to put on the market.
Why so many makers have release a lot of new chassis, then Yokomo is still the same?
At least to have an improvement version of that 1 appeared in LRP masters.
I hope this car could have a stronger arm than that ones from BD, and a carbon protective battery case with strap to fit LIPO batteries.
Maybe will have LIPO allowance at next year in my town races, to finish the tragedy of these chinese "trashy" NIMH and the neighbour cities have allowing already to using it.
#8267
Part# zs010rt and zs010ft (Yokomo aluminum CVD with steele axles) I have had good sucess with this unit... Just make sure to really crank down on the set screw holding the pin....
I don't know the part # for the Yokomo aluminum universals but i don't recomend it for anything except stock racing
#8268
Meshing
Just wondering whether anyone knows whether a 68 spur would mesh with a 28 pinion ie would the pinion reach the spur or is the spur too small?
#8270
#8271
New Yokomo pro tools
just got back from Yokomo USA
they got in the new Yokomo Pro tools
( you can adjust the length of each tool)
PART# DESCRIPTION
YT-1200P 2.0 MM ALLEN DRIVER
YT1150P 1.5 MM ALLEN DRIVER
YT-N50P 5.0 MM NUT DRIVER
YT-N55P 5.5 MM NUT DRIVER
YT-N70P 7.0 MM NUT DRIVER
YT-DP1P #1 PHILLIPS SCREW DRIVER
YT-DP2P #2 PHILLIPS SCREW DRIVER
YT-CS1 160 MM FLUORINE COATED STAINLESS STEEL SCISSORS
PART# DESCRIPTION
#8272
PART# DESCRIPTION
PART# DESCRIPTION
Or Caps? Shirt?
#8274
Thanks!! Will follow your advice on the spool.. . and . . . .
please make one with three x's before the L!
I made the switch to lipo, and do i need the BP-118PH to keep the packs in or just use tape? What do you guys use?
#8275
Jason C,
Thanks for the heads up on new arrival of parts!
First time i went to YOKOMOUSA!!
Nice to see old yokomo kits!!
And for those who are looking for the Team Suzuki, Alumunim Knuckles!!
They still have a few!! These are very hard to find, the production run of team suzuki is very limited.
Lem
Lem
#8276
new yokomo cars
hey all: What's the latest on the new yokomo 1/10th electric sedan masimi has been testing? Also will they offer a new 1/12th pan car because they seem to do well with that type of car? Thanks
#8277
I was wondering if someone can help me.
I know this is kinda a newbie type question but when people put the droop value onto the setup sheets which distance is this actually measuring?
I ask this as I recently had a look at the hudy setup book and this says that the droop gauges and the blocks actually measure downtravel and that droop is the distance the car needs to lift before the tires lift off the surface.
If Martin could answer this it would be great as Im actually going off his carpet setup.
#8278
i use hudy blocks to measure droop/downtravel however you want to name it.
atm i usually run 6mm front and 5 - 5,6 rear
make sure the car is totally flat on a glasplate before setting droop
then place the car on the blocks
then take the droopgauge and measure the underside of the wishbone directly under the outer hingepin
i will post pictures of how i measure in several minutes i think
#8279
I tried the method at setting the car on a block to a height of the droop I wanted i.e 6mm and then setting the setscrews so they just lift off the surface and it was different to the droop guage.
#8280
the promised picture
