Yokomo MR4TC-BD
#1832
#1833
Cool Rob! Sounds good!
Well ran the BD with a homemade spool and locked center pulley. Ran pretty good in stock class. Got the fastest single lap time so far for Stock. My "Team mate" Ortiz out qualified me by almost 2 hundreths of a second for TQ spot. I got to drive his car after the mains. It's dialed!!!
The BD so far is a very good and durable car. I haven't rebuilt the diff yet and it's still silk smooth. Even after several runs in Mod and 19t. Carpet and Asphalt. Plus it's proven to be very easy and fast to work on. I like this car alot!
Question for you guys. Does the battery tray fit the newer 3600, 3700, and 3800 cells?
~Jimmy Mac
~Jimmy Mac
#1835
Sounds cool. I wasn't sure if they'd have another "battery tray" for those cells. But looking at mine with 3300 would explain they they are kinda "loose" in there. Might even explain why some people have problems with batteries flying out. I haven't had any issues with batteries flying out except when I was T-Boned.
#1836
Originally posted by noline
Can anyone give me all the part numbers to make a front diff for the Yokomo BD also does the drive train needs to be worked on or is it all ready freed up do I need to degrease the bearings.
I would degrease the bearings regardless of what car you run. Then use a thin oil and put a drop in them.
The battery trays should work with whatever cells you are using.
#1839
R/C Tech Elite Member
Originally posted by Matt Howard
If by saying "light oil" you mean "heavy grease", then you're right At least mine had the same heavy grease that all the stock yokomo bearings had in them. They spin much better if you spray them out and reoil them.
#1840
I was just kidding with ya the kit grease/oil is pretty heavy but it will help the bearings last a bit longer. As anal as most people are nowadays about efficiency and all I think most of us just sprayed them out and reoiled them before we even built the car, I know I did
#1841
Even went so far as to get the Boca's....
They are very nice....Better than the Acer's ever where in my SD...
Stephen <><
#1844
Originally posted by flysti
so what is people's thoughts of the BD compared with other cars they have owned. i currently own a fk05 wich is trully awsome but i have always had a soft spot for yokomo (all exept for shaft drive), but that goes for any brand really.
PLUS IT IS SO VERY CONSISTANT>>>>LAP AFTER LAP....I am faster just using this car....Even in Stock class.
Hope this helps,
Stephen <><
#1845
Originally posted by Chris Brown
What springs are people running? I was wondering if I should get the Rayspeed long spring set or the Yokomo or both.
Hope this helps,
Stephen <><
