Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 08-01-2008, 03:23 PM
  #13201
i sure marcos j uses plenty of protection when handling each chassis especialy when he has 2 at an time
Smoking motor.. is offline
Old 08-01-2008, 03:26 PM
  #13202
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Marcos.J is offline
Old 08-01-2008, 03:39 PM
  #13203
Originally Posted by Marcos.J
Well what go on the tour stays on the the tour.....
Old 08-01-2008, 05:27 PM
  #13204
shadow102's Avatar
Trader Rating: 21 (96%+)
Check this out...drift cyclone. i really like the orange hopefully i can get one stateside
shadow102 is offline
Old 08-02-2008, 10:29 AM
  #13205
STLNLST's Avatar
Trader Rating: 32 (100%+)
That orange is sick. I'd get one and race it. What makes it a drift car....the tire's??? I bet rcmarket would have it before you could get it state side.
STLNLST is offline
Old 08-02-2008, 10:45 AM
  #13206
John_S's Avatar
plus a rear spool and a whatever the hell that is on the front
John_S is offline
Old 08-02-2008, 01:47 PM
  #13207
Got my hands on the new cyclone TC this week but have come across a problem. There is a lot (1 - 2mm) side to side movement in the layshaft fixing, it's looks as up rights the bareing sit in are to far apart giving this slop.
Has anyone esle come across this issue?
apologies if this has already been asked
blueskieshlg is offline
Old 08-02-2008, 01:53 PM
  #13208
shadow102's Avatar
spread the pulleys apart so they hold the bearings out.
Old 08-02-2008, 04:50 PM
  #13209
SpeedySST's Avatar
Hi guys! Im sure this is in here somewhere but I cant find the answer. I just purchased the LRP 13.5 motor with the Sphere TC. Im running the Cyclone with the 16t pulleys and a 104 tooth spur. What size pinion am I looking at to get a good ratio? Will I need the brushless motor mount? Thanks for your help!!
SpeedySST is offline
Old 08-02-2008, 05:34 PM
  #13210
KHoff7's Avatar
Try a 91 tooth spur gear and pinions in the 50's should do good depending on your motor.
KHoff7 is offline
Old 08-02-2008, 10:44 PM
  #13211
STLNLST's Avatar
We run 96 spur with either a 51 or 52 pinion out at Speedworld. It really depends on your track layout.
STLNLST is offline
Old 08-03-2008, 08:56 AM
  #13212
SpeedySST's Avatar
Hey thanks for the help! We are running a fairly large track in a parking lot. When I ran brushed I was running 36/104 and it was coming off at about 190 deg with a Stockstar using MuchMore 36 tires.
Old 08-03-2008, 08:57 AM
  #13213
shadow102's Avatar
i am running a 92 spur with a 52 pinion here
Old 08-03-2008, 11:29 AM
  #13214
cheers for the info shadow102, simple when you think about it!
Old 08-03-2008, 12:49 PM
  #13215
cyclone speed's Avatar
hi i would like to corner faster with my cyclone moor speed what should i change please it will be very helpfull . If you need any information on what i am running ask me and il tell you i really need help.
cyclone speed is offline
