Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 09-02-2006, 08:59 PM
  #5191
Trader Rating: 32 (100%+)
Got a blue one Joey!
racenut123 is offline
Old 09-02-2006, 09:13 PM
  #5192
dawgmeat's Avatar
I'm 1 front diff away from from carpet season
dawgmeat is offline
Old 09-02-2006, 11:04 PM
  #5193
bxpitbull's Avatar
Originally Posted by AZDemille
Just completed building my Cyclone. The kit comes with a 100t spur. I'm using a Novak Brushless 4.5. Novak recommends running a final of 9.75-10..25 with this motor. Here is my problem: With the 100t spur you have to run a 25t pinion to get a final of 9.75. At 25/100 the pinion does not get even close to mesh up. I can get to 9.75 at 32/128, but I don't know if the large spur would clear the rear graphite brace. Who else is running a Novak 4.5 in this car and what gear ratio are you running? Thanks so much.
Ron
I am running a Pro 4. Internal ratio of 2.4375 is the same on both vehicles. With my 4.5, I am running 98/24 and then I switch up to kill a little bit of low end, I go to 98/25 or 26. Talk about rocket! The car will be sick sick sick and the temps on the motor max at around 130. Depending on the cells you are running, the runtime will be in the neighborhood of 8-10 minutes. Ya'feel me!
bxpitbull is offline
Old 09-03-2006, 12:45 AM
  #5194
hi
any one can help me which on-line shop can buy the UNIVERSAL AXLE
part no 75187, thank you
rayspeed is offline
Old 09-03-2006, 01:37 AM
  #5195
AngryAsian's Avatar
Originally Posted by DavidAlford
108 is the biggest you can get on the car without some work. 110 pokes out the bottom just enough to make it not worth trying. With the new aluminum heatsink you have no problem with either gear.
110 is fine.... It sits almost perfectly level out of the chassis. Perhaps 0.5mm out.
So far I've not had ANY issues with it running asphalt outdoors with a Novak 4.5 It would be very rare indeed to bottom of the chassis completely, and perfectly level to start grinding that gear. I did some curb hopping experiements (erhm./ on purpose of course.. 8cough*) and there were no isses. When taking a ripple ride - the car always jumps front the front bumper acting as a ski ramp. Or the car rolls.. no scratches down the centre...
marcos. J has had the same experiences...
AngryAsian is offline
Old 09-03-2006, 02:44 AM
  #5196
rayman's Avatar
The spur assembly came loose and the grub screw was the culprit. Is this common for the cyclone? The motor kept revving but the wheels weren't turning.
I thought it was the pinion spur mesh that got loose or the one way broke without hitting anything but it turns out the spur itself came loose.
rayman is offline
Old 09-03-2006, 06:39 AM
  #5197
protc3's Avatar
Trader Rating: 13 (100%+)
that is a common problem.use some blue locktight on the grub screws and that will end.
protc3 is offline
Old 09-03-2006, 07:57 AM
  #5198
BillyCaldwell's Avatar
Like jason said, also check it every so often cause they will still work loose but not as bad.
BillyCaldwell is offline
Old 09-03-2006, 02:16 PM
  #5199
floodo1's Avatar
maintenance my main man
floodo1 is offline
Old 09-03-2006, 03:54 PM
  #5200
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
yes the 110 fits just fine its needed if you want to run the 3.5 brushless motor, and by the way , its FAST!!!!!!
Marcos.J is offline
Old 09-03-2006, 04:25 PM
  #5201
AngryAsian's Avatar
What FDR are you using to run it Marcos?
110 / ??? = FDR??
Old 09-03-2006, 04:54 PM
  #5202
Super Moderator
Marcos.J's Avatar
110 / ??? = FDR??
110/23 for a fdr of 11.66
Marcos.J is offline
Old 09-03-2006, 06:17 PM
  #5203
protc3's Avatar
im almost ready with my carpet kit.here is what i have so far
protc3 is offline
Old 09-03-2006, 07:07 PM
  #5204
dawgmeat's Avatar
when?????????????????????????????????????????????? ?????????????
dawgmeat is offline
Old 09-03-2006, 07:10 PM
  #5205
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Its worth the wait believe me. This car is sick with the BMI setup.
L.Fairtrace is offline
