Tamiya F104 Version 2
#946
There is no non-pro version of the F104 V2 currently
#947
They do. I just checked.
However. If I were you I would wait for the titanium edition which will be about $270-300 unless you need one right now. That kit will include aluminum motor mount and a body, which you will need to buy anyway and they cost about $70+ if you buy separately.
#948
What's the eta on the titanium edition?
#950
Help.......... I haven't run onroad since I had an F103L(Indycar) back in the early 90's. Ran that thing into the ground, and loved it.
Looking to get a new toy for the track, but with all the F104 models I have no idea what to do. It may or may not get raced, but will be on the track 90% of its run time. Indoor carpet, about 30x80'.
So the question is,
F104W-GP, F104V2, Black, Titanium? I don't even understand the differences between the V2 models at this point. I'm thinking I'll run rubber tires and probably 17.5 or 21.5 motor combo. Any input on chassis choice would be a HUGE help. Thanks, Joe
So the question is,
#951
So the question is,
So the question is,
The w-gp is is designed for foams and would need more to to be rubber tire ready with less tunability
#952
I would suggest any of the v2 models, the only difference between them is the color of the aluminum and the extra goodies included. With the v2 chassis kit you will need the upgrade motor mount, the black and titanium editions include it.
Perfect, thats the info I was looking for
#953
So the question is,
So the question is,
#955
Here's the latest how-to article:
http://www.rcformula1.com.au/index.p...th-blinky-escs
We post new F1 content most days. If you'd like to receive notification in your Facebook news feed then please Like us on Facebook here.
#957
Who designed the shocks on the f104? they should be fired... It's probably the same person that included the plastic motor mount
I haven't seen a worst shock since.... Nope, it is the worst ever...
How are they suppose to work? both are mounted upside down, with no o-rings at that end, and a hole in the cap
I left a little part of myself on every piece of carbon that needed to be sealed... I don't remember my glue taking that long to dry
#959
As for no o-rings....huh? I'm looking at the manual on line right now and there should be o-rings on both sides of the shock. Are you sure you assembled it right? There are 2 o-rings on the plastic cap side...one inside the cap and one around the outside of the cap. On the other side of the shock there is an o-ring in the bottom cap.
#960
You can thank AE for the design as they first came up with the concept of an even pressure shock. Its actually quite an ingenious idea...by having the shock shaft come out of both ends of the shock the pressure on both sides of the piston will always be the same making for the only truly neutral shock.
And yeah, there should be o-rings at both ends of the shock.
