Xray T1FK05
#1261
Originally posted by Midnight
Man that looks good.
What if you mounted the antena mount on the top deck, would that give some xtra room and also get the antena away from all the wires. Or would that be to much weight up high. Also how close can you mount your gtx before the heat start to play a part in performance.
You could put the antenna mount on the top deck, but I hate putting any weight above the top deck, even battery wire weight.
I drilled a little hole on the side of my RX to re-route the wire right to the antenna mount. This way it won't be near the front belt.
I buy these female RX connectors from my LHS and have a special crimping tool for the small female contact inserts. For the GTX, you can use one regular female connector + a 2-prong (receiver battery type connector) for the ON/OFF switch instead of the big Novak 5-prong harness. This way you can make your wiring the perfect length.
As far as heat is concerned, most of the heat goes to the back when the car is running.
#1263
Anyone know what weight oil comes in the 05 Kit?
#1264
30
#1265
Originally posted by kidDynomite
tc3Guru, I have a Novak RX with a GTX. To make room, I used the 2 most forward servo mounting holes on the chassis. But I had to shave off about 1 - 1.25mm of the servo mounts and extend the slots on the servo ears toward the servo body. I also shave down the antenna mount on both sides and counter sunk a new hole next to the servo. Now there'e enough room to lay it all down and still have room for bigger pinions.
#1266
Hey guys,
almost done building mine. Quick Q's for you xray xperts
- Do I need to rebuild the preassembled diff, or is it correctly built from the factory (ie greased properly, with graphite grease on the trust bearing, blablabla). I did notice it was a little on the loose side and tightened it already
- Lower a-arm mounts: how to make sure these are mounted properly? Mine bind like hell... when you tighten the screws these things turn too...
- lower a-arm mounts / rear toe in: do you guys use shims or clips?
Besides that, the parts quality is just amazing... absolutely unbelievable part fit. Definitely worth the price!
Thanks,
Paul
Thanks,
Paul
#1268
I polished the pins using metal polish first and then I put the hingepin in a dremel, and ran them through the arms until the dremel started to bog down. As the pin gets hot it gets hard on the dremel. I did this a few times letting the dremel and pin cool down between runs.
When tightening the pin mounts work back and forth, don't tighten one all the way and then do the other.
Ermm I'd use AE stealth diff lube on the balls, not black grease.
#1269
Originally posted by Lonestar
Hey guys,
Thanks,
Paul
Hey guys,
Thanks,
Paul
#1270
See here for pics: http://www.mytsn.com/publ/publ.asp?pid=10063
PS: I apply a drop or two of bearing oil to make the Mugen grease a bit lighter (less stickier as it is meant to be for GP centax trust bearing). Do not even bother using regular/normal strenght grease as they will just smear away as you run the car.
#1271
If you use 2 or 3mm aluminum spacers, polish them smooth for less friction on the pin holders, or you can use the teflon shims as well.
#1272
Originally posted by Patriiick
You need to disassemble the diff, use associated black grease.
Lower arm mounts: Mine bind too, but i try to live with it and slightly enlarge them.. it s more a pb at the rear for toe in that the front where mine are 100% free.
I switched to aluminium shims..
cheers
cheers
#1273
All,
thanks for the FB.
I don't think anyone has clearly answered, but I take it the diff needs to be disassembled right away... I usually use stealth lube on the diff balls and graphite grease on the trust bearing. That's the typical AE setup, and it's treated me great for years.
Duckman: I tightened it because it was slipping like hell (in my hands during assembly) and I thought it was assembled properly (ie greased)... Had I not tightened it, it would have gotten worse. When a diff breaks in, it loosens up (the thrust bearing spring or Belleville washers actually soften)
A-arm holders: I'll do my best, thanks all for your inputs. With rubber we use 3deg, and as you can imagine nothing sits parallel to anything else anymore, so I guess a slight bind is not surprising after all... it'll break in. I'll also install Aluminum shims.
Any trick on a quick way to get the diff off the car without pulling half the chassis apart???
Thanks a lot!
Paul
thanks for the FB.
Thanks a lot!
Paul
#1274
That is becoming a common problem with the newer car designs. Pulling the diff out seems to mean undo your whole chassis!
My TRF415 has the same issue.
#1275
Just busting everyone's chops. I really like the new FK05 one of my racing buddies has it and man it layed it down...Great to see all the new cars coming out are all very competative.
Stephen <><
