Xray T1FK05
#3587
Originally Posted by 1armed1
Anybody have a set of eccentric bushings, part# 302074 they can sell me?
I can pay through paypal.
Everywhere online that takes paypal doesn't carry that part.
Dayton
Dayton
#3589
Originally Posted by dmayhew25
What do you guys think of my Race ready 19T for vegas? Any helpful hints anyone can provide for my car?
Finally got her under weight, comes race ready at 1435grams, just 10 grams under, think I will add a motor fan. with a stock it is close to 30 grams light. . Took some work but got it handled. Took it up to Gilroy's carpet track for some practice the other day and she handled awesome!! Can't wait for the race. Thanks in advance for any input.
#3590
I don't have the patience to sift through the 90-odd pages at the moment, but can someone tell me exactly what would be needed to be purchased for the FK05 to run in stock/19t rubber carpet classes? I know there are a handful of things needed, it would be helpful if someone could break it down for me.
Thanks,
d
Thanks,
d
#3591
Originally Posted by Roger
Your set up looks very similiar to my Gilroy set-up. Are you using the .75mm bushings in the rear ? You might want to try a front 1.0mm swaybar also. Goodluck at Vegas.
#3592
You will need some tuning springs probably a set of 20 and 22.5lb spings (~$15 for a set of 4) and maybe 25lb spings. A set of lowered suspension holders ($6.99) would also be helpful
If you don't want to tape your batts you will need the battery strap. ($37.99)
Depending on your track you may want to run a 1-way instead of a front diff, if this is the case you will need the multi-diff ($59.99)and spring steel stub axles for the front (40.99).
The above items will cover 90+% of the carpet and asphlt rubber tire conditions out there. For the other 10% of extra low bite surfaces you will want the 2mm chassis ($79.99)
Cost wise compared to the Corally it is about the same. Corally springs are about 1/3 less but the optional suspension holders are more ($34 for a set). Optional stub axles are not required with the 1-way but you will need to buy both the 1-way and spool to cover all condtions working out to about the same price and X-Ray's stub axles and 1-way. Optional chassis are a bit cheaper than X-rays but are also more ciritcal.
#3593
Anyone know if X-ray has plans to change the rear
arms to run foams? I want to get one sometime in the future, but I don't want to cut my tires or mod the arms. Anyone have any updated info about issue? Also can you use the battery strap with 3700 cells? What are some good upgrades for carpet racing and durability. Thanks guys.
#3594
#3595
For foams you have to mod the rear arm and I suggest modding it for rubber tires as well. With Rubber tires should you have a hard impact that flexes your rim into the shock end your shock will come off or break but with the modded arm you game some clearence and this is much less likely to occur.
Mark
Mark
#3597
Mark
Mark
#3598
Dan
The rear arm mod. Is that you cut the little bit off the arm where the shocks screw into so you can run the wider hole with foams without the rim rubbing on the shock
If you have the instructions it's detailed in them.
DZ
I 'll have my Fk05 back before the end of the week.
DZ
#3599
looking through speedtechs upgrades for the 05' whats the solid axle all about?
#3600
Originally Posted by DZ
Dan
DZ
DZ
