Like Tree1Likes
Xray T1FK05
Old 09-11-2005, 11:20 AM
  #3571
1armed1's Avatar
Trader Rating: 79 (100%+)
thx for the info.
Dayton
1armed1 is offline
Old 09-11-2005, 11:43 AM
  #3572
1armed1's Avatar
What is the largest 64p spur that will fit on the 2.5mm chassis with little or no modifications?
Dayton
1armed1 is offline
Old 09-11-2005, 11:46 AM
  #3573
lbckevin's Avatar
Trader Rating: 105 (99%+)
116 , 64 pitch spur is the largest. I would recomend PRS spur gear.
lbckevin is offline
Old 09-11-2005, 11:49 AM
  #3574
1armed1's Avatar
Thanks,
Where can I purchase prs at online?
Dayton
1armed1 is offline
Old 09-11-2005, 12:05 PM
  #3575
dado11g's Avatar
i use a 120 on carpet when using a stock, it hangs out the bottom about .25mm and is perfectly safe when used on carpet. use a prs
dado11g is offline
Old 09-11-2005, 12:09 PM
  #3576
1armed1's Avatar
Thx dado, where can I get the prs online/
Dayton
1armed1 is offline
Old 09-11-2005, 12:11 PM
  #3577
dado11g's Avatar
sorry... idk. i buy pretty much everything locally.
dado11g is offline
Old 09-11-2005, 12:14 PM
  #3578
lbckevin's Avatar
You can get them at EAmotorsports.com .
lbckevin is offline
Old 09-11-2005, 04:21 PM
  #3579
1armed1's Avatar
Got to looking at my car, the rear diff sets at an angle.
This is not correct is it?
I took it apart and the eccentric bushings have different offset.
I called the guy that I got it from and he said that the 2 bushings in it are the only 2 that was in the kit when he built it.
Any help on this would be great.
I also have a post for some parts I'm looking for in the wanted forum.
Dayton
1armed1 is offline
Old 09-11-2005, 04:24 PM
  #3580
scoobydo's Avatar
Dayton
Hes not telling the truth. The kit comes with 2 sets of eccentric bushings. One lower than the other. They are so you can choose your preferance of diff height. He just mixed the 2 sets by accident.
scoobydo is offline
Old 09-11-2005, 04:28 PM
  #3581
1armed1's Avatar
That's what I thought.
Does anyone know where I can get parts online that takes paypal?
Dayton
1armed1 is offline
Old 09-11-2005, 05:03 PM
  #3582
hpipro321's Avatar
precision rc does they are really good bout paypal
www.precisionrc.com
hpipro321 is offline
Old 09-11-2005, 05:15 PM
  #3583
polesitter61's Avatar
Actually one set of the diff adjusters has the hole in the middle and the other set is offset, you flip them up or down depending if you want the diff high or low.
polesitter61 is offline
Old 09-11-2005, 05:19 PM
  #3584
HarshGuy's Avatar
There are 2 "sets" of eccentric bushings, one with the hole on the "middle" that you use for setting your transmission in the "middle" (althouh you need to install it with the tensionsers facing up), and another set with the hole "offset" you install them with the offest upwards for "high" transmission setting and downwards for "low" transmission setting.
HarshGuy is offline
Old 09-11-2005, 05:29 PM
  #3585
1armed1's Avatar
Thanks for the info guys, I understand how they work and what comes in the kit.
He told me that the ones in the car are the only ones that came in the kit.
The ones in the car, one is centered and the other is offset.
Dayton
1armed1 is offline
