Finish Line's "F" brush
What's the key to getting good numbers with this brush for 1/12 scale? I've tried breaking them in for 10 minutes @ 2.5v and the serrations still look new. How long does it take before they start showing the type of power that everyone has hyped about?
1st off the F-brush is not exactly the greatest thing for 12th scale, they work verry well for 6cell applications but they are a torq brush and seem to be down a bit on power at the lower voltage.
To get the best results with the F-brush in an RM first shave the brushes to advance the timing a little bit, to a brush width of .158. Then put thin ( about 1/2 the width of the eagle or trinity brush cutter ) verticle cuts in both the negative and positive brushes. Spring tension should be ~ 7 to 7.5fs + and 6.5fs -
break in time should be about 2-3 5min cycles @ 2V
In general high silver conent brushes shuch as Putnam greens work verry well for 4cell applications.
To advance the timing you narrow the brush on the trailing edge only.
Just a little info for everyone. I built Jeff Daygers motor at the Snowbirds with the "F" Brush. He TQed 1/12 GTP Stock with this brush. I used a full face (no cuts) , green springs , squared the hoods , and shimmed it to the center of the magnetic field. I broke it in for 60 seconds @ 1 volt. I sell the brushes at www.kinetixrc.com
Originally posted by Artificial-I
I just got some for my vehicle. Got any links or diagrams on this?
Also what is the big deal about breaking a brush in. Why not just break it in on the car or basically wait till it gets full power.
actually the track is the best way to break it in.. would you rather burn through a whole good run on your turbo 30? or burn it on the track.....
ask mike reedy how he builds a stock motor for his team guys..
F brush is a great brush.. ive been runing them in oval for a few weeks now.. ive broke stock record 3 times on them.. i think they work best in the 4 magnet motors... but well in two as well..
PS i have about 20-25 builds on my f brush.. there still getting better with every rebuild,, (5-6 runs).. im going to guess ill get 50-60 runs ut of the pair.. the serrations are finnally gone.. took 18 rebuilds
Rebuilds?
I just finally pulled my old brush out of my motor and put in the F-Brush.
All I have to say is HOLY ***** its fast as ********.
From the first punch. My car acts completely different. I have a slipper clutch and diff....and before I would punch it at a dead stop and it would slip for like 1-2 seconds...and it would kinda take a sec to get that slip at first.
Now its instant slip all the way till top end. Its amazing. Its like a whole new motor , the thing drives completely different. Its like I either just bought a battery thats twice as good or a motor thats twice as fast but with the same relative rpm.
Before = WRRRRRZZZZZZZZZZEEEEEEEEEEEEEEEEEEEEEE
Now = WRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRREEEEE EEEEEEEEEEEEEEEEEEEEEEEEE
Its amazing. Everyone and their grandma should get this. I bought a few of these and also came up with a neat trick for cleaning the comm. Now I dont have to worry about getting it lathed all the time.
Also my old brushes were completely flat? Is that better? Can I still use those. I think my sides were getting all weird and chunked off. I think I chucked them, but thats ok they were crappy compared to the F-brush. So how many runs or builds (if you can explain it) can these take?
