Old 03-06-2005, 01:59 PM   #1
HVAC25000's Avatar
Trader Rating: 19 (100%+)
Default Charging NiMH
Hi. I have a pack of GP3300s and have a couple questions too. I tried to find answers elsewhere, but there is so much conflicting info out there...
How many times can I charge these in a day? I've heard everything from NiMH batteries don't care, to only charge them twice a week, so I'm quite confused.
After I charge them, should I give them a period of time to cool down before I use them?
I used to know some guys who would charge their NiCds inside a cooler with icepacks in it to keep the batteries cold so they would take and hold a charge better, is this a good idea with NiMHs?
Do they need to be discharged after use and before charging again like NiCds?
Should I store them with a full charge?
Thanks!
HVAC25000 is offline   Reply With Quote
Old 03-06-2005, 02:32 PM   #2
Cole Trickle's Avatar
Check this: Fukuyama guidelines
That shold answer most of your questions, if not all.
I've been following the Fukuyama guidelines for a year now, nd with very good result. Only exception, is I keep the temperatures sligthly lower, from 50-55 degrees celsius.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 03-06-2005, 03:06 PM   #3
schmelme's Avatar
The sooner you run your packs after a charge the better they will perform. Do not cool your packs while charging the pack should get warm-hot to touch. Most guys store their cells partially charged.After you run them put them in your box but make sure you tray them before the next charge.
schmelme is offline   Reply With Quote
Old 03-06-2005, 11:05 PM   #4
HVAC25000's Avatar
Ok, thanks. Now that I have that info, back to my first and most important question.
Old 03-07-2005, 04:11 AM   #5
Two times should be fine,(is fine actually) but most people, never charge their good packs more than once a day
Kyosho Evolva M3 / Kyosho Lazer ZX-5 SP / Xray T3
aantonis is offline   Reply With Quote
Old 03-07-2005, 05:13 AM   #6
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Here is another.
http://www.teamtrinity.com/tips/batts.asp
Artificial-I is offline   Reply With Quote
Old 03-07-2005, 05:30 AM   #7
Originally posted by Artificial-I
Here is another.
It seems to me, this apply to the first generation of NiMh cells. I think it tend to be outdated a little
Old 03-07-2005, 06:31 AM   #8
Send a message via MSN to Emil
Charging more than once a day will result in shorter run time for the second charge. This is due to an increase in the cells IR (internal resistance). This also means that you will have less power/punch.
Hope this helps.
Emil
Emil is offline   Reply With Quote
Old 03-07-2005, 06:47 AM   #9
Hope this helps.
Emil
I agree that runtime will be shortend some, but actual the packs are more punchy the second time But remember to let them cool down before the second charge, that is 1-2 hours.
Old 03-07-2005, 11:38 AM   #10
HVAC25000's Avatar
Thanks for all the info, everyone!
M11 charging- AA NiMh D Hunt 3 Electric On-Road 12 12-26-2006 07:17 PM
1100 mah nimh charging blackdog Micro and Mini Scales 6 12-26-2006 07:26 AM
Need help with charging AA NIMH MrRolla Australian Racing 7 09-26-2004 04:45 AM
Charging NiMH omyers Electric On-Road 1 06-28-2004 07:40 PM
Charging Nimh??? Lerlo Electric On-Road 1 04-12-2003 12:08 PM
