Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012
#526
That's good information. Have you tried matrix? I plan to run Enneti (Have not purchased any as I am still finishing the kit) however am curious if the matrix tires are one that has this issue.
#529
Another Noob question here...
What do you cut out on the body for 10th sedan. I've seen all kinds of variation on the internet.
Hole for fuel gun
Rear window but how big? Follow the dashed line on the body?
Side windows?
Any holes for access to the fuel door or how do you rig it?
Thanks for your help! I'm running a Protoform SRS-N is that a good one? I'm liking how it feels on the track. The body I got with the car was cut out but I know its not to rules, this is why I am asking. Id like to have one in spec when I show up at a big track so I don't look like a doofus anymore than I already am.
Hole for fuel gun
Side windows?
#530
Hole for fuel gun
Side windows?
Hole for fuel gun
Side windows?
The SRS has lots off downforce wich can slow you down if not set up right.
But its a real good body to get/have grip.
Nobody are regarded "doofus", but some(/not all) "former Champions" get real hasty on the track when in a final, so one has to endure sometimes remarks from them. We all have been(/still are) there. But keep focused on your driving/learning curve and have fun.
#531
Fellas quick question, for you non bias racers, if there are any in here.........who has switched from a xray or Cap to 747? If u have...what r some differences if any? I ask cause a guy i race with has 747 n His car flat out can turn under anything! Not just my cap but all caps n xray too.....i watched a very good mugen driver make mistakes trying to keep up with this 747! The mtx5 just couldn't turn with the serp........
#532
Hole for fuel gun
Side windows?
Hole for fuel gun
Side windows?
30mm in any direction for fueling. (Which can not intersect with another hole).
You are free to cut out side windows and rear windshield. As long as its cut in one consecutive hole. Not lots of little holes, and no air scoops.
Most modern cars (all?) have their fuel filling cap inline with the motor, so, if you cut your 60mm cooling hole centered over the fuel cap, then it normally is inline with your motor and allows you to fuel the car.
You need to find a balance between cooling, and aero. The smaller the hole the better, as long as your pit guy doesn't have any problems, and you can keep your motor cool.
My car has the entire rear window cut out, but I have noticed the trend to only cut out the lower half of the window. I am thinking it will cool the car fine, and keep the air smoother over the rear wing.
As for rigging your fuel door, with a large hole you can use a pull tab (zap strap only connecting to the tank door), but the fast guys will run a long zap strap from the fuel lid thru a hole in the body, then back in to the rear shock tower. Its more strain on the tank lid, but your pit guy can grab the strap, which automatically opens the tank, fill the car midair, and then release the car quicker. (zap strap=zip tie)
Shawn.
#533
#534
Thanks for the response Dan, Quick question, not sure how connected u are with serpent, but something thats really holding me back is the fact that 747 has been out for what maybe a year or less? N we always make fun at races when we talk R/c that serpent is due for a new car in a few months I just dont want to get the 747 n then 3mos later the 769 dropsis a new car in the works, or r they going to stick with this one for awhile? or atleast will the 747 b able to b upgraded to the next one?
#536
Capricorn fast car but too inconsistent
Serpent is the one i just bought and i hope it's a great and fun car to drive
#537
Good luck, n keep me posted on your findings........cause I def got my eye on 747, Rightnow I'm reading all 36pgs to get a idea of what to expect. Good/bad
#538
i drive a nt1 but in my oppinion the 747 is the car to buy at the moment.
Still with harder shock oils front and rear, you will get much more steering in any car. Or harder springs all around. Basic setups are too safe for quick laptimes.
Still i am using basics now to get more consistancy in my driving and the times go up.
#540
Pass you soon...
