Yokomo GT-4 Thread
#663
R/C Tech Elite Member
Originally posted by jwf_frani
i run mine at 60mm and under at revalation. I know Chris t.
was running his at 58mm at the nats. most of it is also to get
a good rollout for your gear ratio plus the car just handles
better for me at 60mm and under.
#664
i have the overdrive option on my car right now but haven't
tried it yet. from what i know you will need to run a 4mm split
to get the rollout even. i just want to see if it is even worth running the tire splits. i would recomend the rayspeed pistons
with 1mm x2 for the rear and 1mm x1 for the front pistons.
#665
#666
I was just going to ask JWF-Frani for the Rev setup myself
I runed my Yok at Rev for the first time on Sunday, and the car was very driveable, but slow. I had 40w oil on all 4 shocks. I will try heavier oil next time, but it would help if I had a setup to start from.
thanks,
Steven Muller
MPP
thanks,
Steven Muller
MPP
#668
heres the rundown on my setup. this is not from the nats just
because my car was way off for the nats.
front: 55wt oil with grey springs rayspeed piston 1mm x1
outside hole shockmount on arm and tower. Note use the
longer shock end.
rear: 60wt oil with green springs rayspeed piston 1mm x2
inside hole in tower
front toe out 1 degree / front camber 1.5
rear toe in 2 each side / camber 2.5
tire size 57front and 61 rear.
longer shock end.
#669
nitro dude i will work on the car this weekend so that i can
give you a better setup on the car. also one of the most
improtant to remember with the GT4 go thicker on diff fluids
and seal it good the car just works better on 100,000wt or
difflock and make sure you seal it good.
RandMan try to post the pic of your car when it gets back from
the anodizer.
the anodizer.
#673
yeat that is for the rear when you run a one way. make sure
to seal it good with gasket sealant or it will just leak out and
it will empty out pretty quick
#674
Randman
It all depends on how much traction you have on the track. For example I just came back from the track because we have an hour race this Sunday, and since we only run rubbers down here and the track is semi-permanent and dusty (low to mid traction) I had to go to 50,000 wt up front and 10,000wt on the rear, the car performed awesomely. Before that i used to have 100,000wt up front and 30,000wt at the rear and the car just would't turn on tight corners and on fast corners it wen't wide.
So as a rule of thumb with differentials I'd say allways the front has to be harder than the rear, and the more traction you have the harder both must be and viceversa.
Now if we are talking about a track with lots of traction(prepared) and on foams I think the way to go would be solid rear and one way up front, so as to not scrub off to much speed on the corners.
AFM
AFM
