New CRC Gen Xi 12th car.....
#303
Got the new kit
Although I will not have any chance running RC in near future, I still bought a new XI kit just for the sake of building it after selling my CK 3.2 4 years ago. I got the little surprise added to my kit. I even bought a full set of tools just for it. although it will be built to be almost RTR, it will probably not seeing any tract for really long time.
The new kit is beautifully made. and it got the new steering block that is closer to the pre Gen-X(my driving skill is horrible, I didn't get the Gen X back due to skeptical of the Gen-X Alu steering wheel shaft). I just hope one day CRC will switch to metric hardware. that will make the perfecting car closer to perfection.
I shall post the car once it is complete or maybe a building progress
#304
Just ordered kit . What spares should I buy?
#305
#306
I would get
Hop ups :
Angled servo mounts : CLN1715
Bag of red low roll pivot balls : CLN13615 ( to be used on steering block with angled mount)
Center spring set : CLN3299
Spares :
One set of extra front end plastics ( Arms CLN3247,Pivot balls CLN3246 Steering CLN3221 ,and Caster blocks CLN3243)
Bearings ( Front axles CLN1248, Rear axle CLN1386)
Hop ups :
Spares :
#307
instock at Timezonehobbies.com
sorry shamless plug
sorry shamless plug
#310
Ok, so here in the UK, over a national weekend, we run 10.5 on the Saturday (4 qualy's and a final) and then mod on the Sunday (same 4 qualy's and a final). I have already built up a Gen Xi conversion kit that I will be using as the 10.5 car, and am waiting for another full Xi kit to arrive to build into a mod car. So, my question is this, how should I go about setting each car up for each class?! Short arms on the 10.5 car, long arms on the mod car?? If so, why?? If anyone would like to give me a good start point for both cars, and the reasoning behind it, that would be awesome! Cheers, Chris.
#311
Short arms on the 10.5 im guess your not running boost, and for the mod if your running boost then the longer arms will give you more stability
#312
Stock setup
CRC Gen-Xi
Body: CRC Black Art Audi R8C
Front Tires: Crc magenta 41 mm glued face
Rear Tires: Crc yellow 42 mm
Batteries: inline
Front springs: .55
Caster: 5 degrees with shims 1 forward two back
Camber: 1 degree
Side springs: whites 2 from all way out & tweaked
Center shock spring: green
Center shock oil: 30wt
Dampner oil: Losi 20000
Front ride height: 3.75mm
Rear ride height: 3.75mm
Center ride height: 3.5mm
droop: tons use wgt shock end
Angled mount for servo
Superstock
CRC Gen-Xi
Front Tires: Crc magenta 40.75mm glued face
Rear Tires: Crc Grey low 42 mm
Batteries: inline
Front H Brace
Front springs: .50
Caster: 10 degrees with shims 1 forward two back
Camber: 1/2 degree
Center shock spring: red
Dampner oil: Losi 50000
Front ride height: 3.5mm
Rear ride height: 3.5mm
Center ride height: 3.25mm
CRC Gen-Xi
Batteries: inline
Front springs: .55
Camber: 1 degree
Superstock
CRC Gen-Xi
Batteries: inline
Front H Brace
Front springs: .50
Camber: 1/2 degree
