Kyosho v-one rrr
#5866
On the VSW006, I don't remember if this has not been discussed so far; I've tried taking away the 2mm spacers and put on 0mm offset wheels, it's CLOSE to the rear hub, but still there's a 2mm clearance, so I guess it it should be ok.
#5867
Originally Posted by Ivan Dickson
That chart is very helpful great info. That's why I like RCTECH so much, always good info. to get. Thanks Tommi.
#5868
Either VSW007 or VSW006 will be fine. You just have to take note of the wheel offset you are using. Please see my two previous threads for reference:
Posts #5400 and #5406 on the next page:
http://www.rctech.net/forum/showthre...37#post2219937
#5869
just out of curiousity, what is the advantage of using a 2mm offset?
#5870
The wheels that come with the WCE kit have a 2mm offset. The setup sheets shows a camber of 0.5. Based on my theory, if you leave it at 0.5 and don't have a coning problem, the 2mm offset would give you better downward force accross the tire than a zero offet wheel.
The ground truth and other theories would be greatly appreciated.
#5871
Originally Posted by rmdhawaii
I tried to find this information out of the Web and couldn’t find anything. Maybe someone has this info at their finger tips. My personal opinion, is that the zero mm offset offers a better distribution of downward force across the width of the tire, based on a more negative camber settings. But that's just my theory - I could be completely wrong.
#5872
#5873
Originally Posted by tommi
It's about "wheel flex". Offset wheels have less flex, giving a more stable and predictable handling comparing to 0 offset wheels.
#5874
That makes senses to me. If this is the case, why would anyone want to use zero offset wheels? Unfortunately, some wheels only come with a zero offset.
Both normal and offset wheels has got different handling characteristics that some like and some don't. To me, it's another tuning option to the "flex" dimension of the car.
#5875
Hope these pics are clear enough, this is how the spacer works on the VSW007. Without the spacer, the shaft will be left sliding in and out of the rear hub. On an alternative wheel hex, 3Racing makes one with 1mm offset, still does not quite work without a spacer. The spacer is doing the job good, no worries; I've used both 0 offset and 2mm offset wheels on the VSW007, no problems at all.
What wheel hexes are you using and what are you using for the 2mm washers?
#5876
#5877
Originally Posted by jag
Thanks. That helps alot.
#5878
Did you ever race the car setup like this? If so, did you find that the wheel rubbed the upright at any time? I know in the past with my 710 if I used Jaco tires in the front, they would rub a groove in the steering arm from flexing and bending. I had to use a 1mm spacer.
#5879
whats a good set up for a big track with sweeping turns traction is good
#5880
