Kyosho v-one rrr
#5206
The stock is in the manual ay?
i had it partially dialed, but he's not used to a one way so its hard to drive. plus hes never had an engine so quick haha... also has anyone else had problems of the dogbone falling out of the front and half of the one way coming out. it happened twice to him today.
#5207
If the dogbone is falling out then probably the front tracking is too wide. Also have a look in the manual, for the section where the one-way is placed into the car - you'll see that some rubber rings are placed in the outdrives, this will prevent the dogbones from moving around too much.
When you say the one-way is coming out, do you mean the whole unit, or the outdrives (i.e. the adaptors which fit into the one-way itself). Again if the outdrives are coming out, then the front-tracking is far too wide.
Cheers, Mark.
#5209
the outdrives
Check all of the settings of the car carefully against the setup sheet, i.e. downstops, width, camber, toe-in/out, anti-roll bars, caster, etc.
Check the shocks, too, to make sure they are working correctly and have no air in them.
Without the shocks mounted make sure the suspension arms fall down by themselves and don't have excessive play.
Cheers, Mark.
#5212
Yea i gave it a good setup today and it was improved on the setup my dad did. but it still felt loose compared to our other cars...
Is the car too loose when you apply power? What are the grip levels like on your track?
It could be that the diff oil is simply too thick, causing the back-end to break loose on power.
Are there other RRR drivers at your track - ask them for a setup and ask them to give your car a spin to see what they think the problem.
Another important point is to ensure you have a 2mm front-to-rear tyre split, as per the stock setup, i.e. the fronts 2mm smaller in diameter than the rears.
Cheers, Mark
#5213
#5214
For Tempe take the roll bar out of the rear altogether, 2-3 degrees toe out on rear and 1 degree on front and 3-5mm droop on rear and nothing on front.
That should get your dad around very quickly especially at Tempe.
Also like markp said try running a less weight oil in the rear diff i run 15,000 and the car has plenty of grip i might even go down to 10k or 7k.
#5215
I have been running this car for some time now and I realy like how this car handles. The car is also very durable and very easy to work on. The only weak parts on the car is the rear shock tower ( which is now upgraded ), alum brake hub and disk , the lower rear hinges pins bend very easy, and the front wheels like to chew on the shock ball ends. Does anyone have any input on how these very minor weak areas can be improved. Thanks in advance for your help!!
#5216
#5218
its a medium grip track, it's on a tenniscourt it has two fast sweeping corners and 3-4 tight corners and its loose at low speed. i think most noticably off power...
I'm going to take it apart the next chance i get and have a look at everything. thanks for all the help
#5220
i'd like to share something iv discoverd... its a program the can calculate and simulate roll center acition...
http://www.performancetrends.com/rc.htm
