Kyosho v-one rrr
#1486
Hey all, quick question.
Can I use the front diff bevel gears out of a rr in the front diff of the rrr.
Thank you. Tenderfoot
#1487
Originally posted by AndyT ©
Check to see that theres no burrs in the housing......i had some very slight ones around the holes and fixed them with some steel wool.
Cheers
Cheers
#1488
thanks for the help. I found the problem, the 2.6 x 12 mm cap screws stuck out through the other side. I ground them down and it slipped right on.
#1489
#1490
Setup station
Thanks guys for your help I will try a few of your ideas next race meet.
Also could anyone suggest a good setup station.
Thanks again
Tom
Thanks again
Tom
#1491
Re: Setup station
Thanks again
Tom
Thanks again
Tom
If you are going for bargin, I have a set of used Hudy Ultimate set up system for sale. It is the older plastic one but comes with board, setup stands, ride height and droop gauge. I will take US$60 plus shipping.
#1492
Originally posted by Racing4Evo
2) It ran fine Thursday night during testing but come Sunday I put my PT in the car. I've heard of other people having problems with PT related glitching. Eric from SoCal also glitched that same day.
#1493
The rumor you all are speaking of..........very true!......and soon!
#1494
I didn't notice that. I'm going to check right now. I get the parts I need from www.japan-rc.com. I see him at the track a lot and he has EVERYTHING for the car.
Dave
#1495
Yeah, so far it's the chassis and fuel tank. It went half throttle into that hole at the end of the straght. Going to fix it on friday. I narrowed the problem down to two things, you tell me which you think is more likely to be the cause.
1) I cleaned the bearings out last time and just light oil and maybe the oil dried up so now the bearings are making electrical noise. The outer hub bearings were in pretty bad shape when I rebuilt them and they weren't that smooth afterwards.
I'm going to get that Yokomo Noise Killer Set. I hope that sh*t works or else I can't afford to race!
#1496
The PT is mounted in the stock location: the plactic mount above the steering servo.
I am going to buy the anti-electrical tape from Yokomo. They call it a "noise killer set. Whatever. I'm also going to stop by Airtronics next week and have them look at my radio because the blue LED broke. Looks like the gods are telling me to go back to KO.
#1497
does kyosho make regular rear springs where the tension is not progressive. ive noticed that going from black to gold doesn't make to much of a difference since both springs are soft for the first 3 mm of travel which is more than half of actual shock travel when the car is on the ground.
#1498
#1499
Jeff are you coming to socal this saturday?
#1500
Originally posted by Racing4Evo anti-electrical tape from Yokomo. They call it a "noise killer set.
