Team Associated TC4
#3421
I actually used a spiral cutting "zip" bit - that worked extremely well - I mounted it to my drill press so I had more control.
I'll post some pics this evening.
#3422
Originally posted by raving-monkey
the front shocks on my car are weird...to set ride height 5mm either side on the front my front right shock automatically needs preloading a bit more than the left...weird....saying that i dont actually get any torque steer whats so ever, or not any that i can see/feel.
#3423
Yea....maybe Ae will change the motor
mount on the TF TC4 so you could use a upper deck like the BMI one. If they changed both the motor mount and the rear chassis battery post they could use a CF upper deck like BMI, but you could lower it down to the top of the wing braces. It would have a much lower CG than the BMI deck. Then just lighten the chassis up and go with CF shock towers.
#3424
Does anyone make Carbon Fiber shock towers for the TC4 yet?
#3425
carbon fiber chassis
i was thinking the same thing. i want cabon fiber shock towers for my d1 or B.m.i.
#3426
No one makes them for a TC4 yet???
#3427
bad diff gears
Well-I finally got put in a situation where I had to dremel a diff gear thinner (white gears that are too thick). I had put it off due to worrying about doing a hacket job-but i got to tell you-it takes a minute to do and you barely take off nay material and when your done-looks like you never touched it.Whew!! I used a stone that is flat n the end. Reddish-fine stone~1/4" diameter. I took a few passes on each side-then cleaned up the holes with a hobbyknife.
Dont know why I ever bought new gears-this was too easy.
#3428
Rayhuang...
I thought you ditched the TC4 and you were driving a RXD?
#3429
Re: Rayhuang...
OH-and I did drive a TC4 Sunday and I came away from the drive Extremely impressed. It rotated so well-it was freakky. More like pivoted-then rotated if you catch my drift.
Like many of us said-think outside the box and eventually you'll nail a set-up on this car and he did.
#3430
Super Moderator
Agreed, I've only had mine for a couple of Saturdays, but I could tell from the first practice run that I liked it, now I'm just doing some fine tuning to get it right where I want, & I'm positive I couldn't have gotten this close to perfect at my local track with my old TC3(I know because I tried & got nowhere). It does have to be set up a bit differently, but it is DEFINITELY responding to the adjustments I make nicely.....
#3431
Originally posted by caleracer45
What do you mean the FT TC4 will probably be a lot different? Like what do you think they will change?
Possible re-tweaking of shock towers and chassis. Nothing major but still small changes. Possible AE designed carbon top-deck.
Lightweight Steel diffs front and rear.
Slightly re-designed A-arms.
Neatest thing though, an all new Aluminum / carbon driveshaft.
All the blue-anodised bling.
Just what I've heard from a little birdie.
#3432
Originally posted by Soviet
WARNING...RUMORS:
WARNING...RUMORS:
-Dave
#3433
What Helical Insert do I need to order for my diff cases?
Length, size etc...
Thanks,
Length, size etc...
Thanks,
#3434
but it would be interesting to here more about this drive shaft
-Dave
-Dave
Yokomo part # SD-644W
#3435
This is probabaly a dumb question but will that Yokomo drive shaft work in a TC4??
