Team Associated TC4
#3061
Thanks for the link. I put the spring on the wrong side. Wish Assoc. would have included the instructions with the part.
#3063
Hi utieh!!
I have some NIB steel outdrives, PM me if interested, BTW where do you race??
I might be interested in you NIB outdrives but I want to try the stock ones first and see how it goes..i'll keep in touch
Do you run 12 mod also? How do you like the car? Are you in "supersport" french class?
See ya!!
#3064
Compairing TC4 instructions to Steel instructions:
Diff bolt, Diff gear & balls, Thrust ball & washers are the same.
the Diff springs are the same, but the instuctions for the steel Diff says 2 are included? I only received one, and you only need one.
Diff nut, rings and bearings are different.
#3065
#3066
Re: Hi utieh!!
Originally posted by Tbevofreak
I race in Montauban, most of the drivers run nitro cars but still we are quiet a few to run electric.The track is ok for both, I've just arrived in the region so I didn't race on it that much yet + its so cold!
See ya!!
See ya!!
#3067
Hi guys.
Gave my TC4 a run for the first time yesterday and I have to say I was impressed
I am currently in the process of putting a setup on for carpet racing, and on the setup I downloaded, it says for the Shims (triangle etc) 2. Does this mean that I should only use one of the shims with 2 tabs on it under each of the blocks??
Cheers
Crashmaster
Cheers
Crashmaster
#3068
I believe that is correct. They go in increments of .025 so a 2 is .050 and a 3 is .075 and so on. You can use a caliper to verify which one you are using.
I had the same question last night when I was putting my TC4 together and looked in the manual. It shows the different sizes in the pictures and the .075 has 3 tabs while the .025 has 1 tab.
bob
bob
#3069
Cheers mate, that what i thought, just wanted to amke sure
Cheers
Crashmaster
Cheers
Crashmaster
#3070
Does someone knows how good would be the stock set-up for rubber on a medium grip carpet?
Thanks.
Gilles
Thanks.
Gilles
#3071
I just put a close to factory team TC4 up for sale, check it out http://www.rctech.net/forum/showthre...threadid=61741
#3072
Originally posted by rs911
Thank's mate I'll see if I can get a hold of some.
#3073
can someone tell me why my rear end is harder than the front? i have all around number 2 piston and 40weight oil with blue in front and silver in rear but the back is harder than the front and doesnt it has to be the front harder than the rear? is there something wrong?
#3074
Thanks.
Gilles
Thanks.
Gilles
Crashmaster
#3075
Originally posted by Crashmaster
What kind of tyres are you going to be running?
Crashmaster
Crashmaster
