Serpent S411
#1336
RATIOS
http://www.petitrc.com/reglages/serp...ng-Springs.pdf
Cheers
Ren
#1337
Yeah I also use a grease (just high temp bearing grease) around the o-ring and where the outdrives exit the case. It just seems logical to add some protection. I also spray my rubber seals with motor spray. This makes them expand a little so it improves the seals. As it is the only leak I have had is when you over fill the diff and it leaks through the screws.....
#1339
Below is a link to a PDF file with all the info you require.
Cheers
Ren
Cheers
Ren
#1340
I couldn't agree more with the praise for this car
As a new owner of a serpent after many years with schumacher and an occasional dabble with Tamiya and xray, the fit and finish of the serpent is fantastic. So much so that a week after building and running the car I ordered a second.
I love the way the car just fell together and was quick out of the box.
I predominately run on carpet so then put Rasmus's Crarpet setup on the car and instantly went quicker on our track then my old Mi4CX - which I'd got going pretty well- by a whole lap! I'm now only a few tenths behind the group of faster racers I'd been chasing for over a year.
Love this car - really smooth, loads of steering and grip, really easy to drive.
Looking forward to the outdoor season next year to see how it goes on asphalt but on carpet its looking good for the winter
Cheers serpent!
Cheers serpent!
Nice, that you could use the indoor set up from Rasmus.
The set up works also with a modified motor as well. Rasmus has now driven the car for about 25 batteries with a modified motor, and he has set 3 new track records. On a track, where he drives about 10-15 batteries every week in the winter season. He now can drive 33 laps in 5 minutes on the track almost every time. Last weekend 8 times in a row. With the previous car (Tamiya 417) it was maybe once or twice every week.
You write the word, that describes the driving of the Serpent: it is EASY to drive - and more important: it is EASY to drive it FAST.
We have tested some more settings, and changing the FR brace to a 1,5 makes the car even easier to drive - but not faster. We also tried the standard 1,4 mm rear anti roll bar again, and changed the damper settings one whole to the 6th. position. Very small changes, you feel it (rear more stable), but not faster.
#1341
Hi mutley001.
Actually ou mentioned here the things I planned on trying next. Raising the shock positions another hole, trying the 1.4 rear roll bar etc so I'll rethink.
At the moment I'm running kit arms and hubs etc so I think my next move should be to go with the hard versions. Do they make a big difference to lap times???
Are people finding them brittle at all?
Anyway - thanks for the info it saves me a buch of testing time!
#1342
Hi,
I think the uk version comes with a 2.5mm chassis and top deck but looking at alot of set up's most run the 2mm or 2.25mm is it best to get this for the UK tracks espcially with low to med grip ? what about top deck thickness ?
Also would I need to change arms, hubs etc to hard ?
Any other items I should get or change for the UK ?
Thanks.
Thanks.
#1343
99% sure that the O ring wasn't twisted too (It was one of the things I checked), but you never know.
Chances are it's probably me doing something wrong anyway.
Anyway, I'll pick up some of that green slime and try that.
#1345
i would keep motor spray or brake cleaner, or any other liquid away for the X seals , they swell up so much. not a good idea. puts extra stress on the seal and if you happen to run it the same day, its likely to be binding up and wearing it out premo. a little shock slime on the outdrive shaft is all that is needed.
#1346
Hi hi,
Is the oil leak from outdrive? Or screws holes? Or the gap from pulley teeth
I've pulled it apart and put it back together several times trying to stop it leaking. Also did this to try and get the thing to stop wobbling (was still wobbling slightly). Maybe this is related to the leak?
#1348
i was talking about the diff seals. in no way or form would you want to expand seals before they are fitted. all it does is create other issues. coming from a Hydraulic background, this is from years of experience. forcing something round into a round hole, it makes the seal out of round. then you compress it, and im sure you know what happens next. but i dont want to argue about it. so lets move on.
#1349
I actually just rebuilt it to check it, as I had it sitting around for 3 weeks and noticed that the rear belt was completely lubed up (and the insides almost dry).
I suspect it was coming out through both, as previously i noticed the teeth completely lubed up and earlier i found the plate where the screw heads are lubed as well.
Anyway it's been 24 hrs and no signs of leaking, so maybe I got lucky this time.
I'll still get some green slime anyway I guess.
