Serpent S411
#3032
ok thanks for the help, i just didn't want to start filing blindly hoping to make then fit better just to break a c hub in the next race lol
#3033
Hi, I sold all my serpent cars and parts, as I was no longer going to race, just wanted to let all you guys know, you were all great and all the help and advice given to me was very apperciated, I still have a xray left over and will try that , I hope the xray guys are as great as all of you have been, but not really worried since I am not really going to race with it just drive with it for fun it was a gift from my sister so have to wait a bit until i can sell it, lol, where she bought the car the hs told her it was the best car to have, apperently he does not sell serpent, I hope I can get back into racing and at that time my weapon will be a serpent, but for now off I go to the xray thread, since it is a gift I will probably hold on to this for a little longer, but once again thanks to all and best regards
#3034
On my normal S411, I do need to remove some material on the c-hub to clear the DCJ but on my LE, serpent has made the changes,the c-hubs have a bigger clearance for the DCJ joints, so no need to enlarge it. FYI I enlarge my old c-hubs by using body reamer, ream it from the inside slowly just about mid point. Its not that hard and will make an almost factory cut like clearance.
#3035
#3036
#3037
#3038
sucks. i have been in and out for over 15 years. its tough to stay out especially since there is nothing else to do around where i live. best of luck to you.
#3039
Instruction DJC
Hope this helps! ;-)
#3041
#3042
Does anyone know if someone makes o rings that will fit the serpent shocks?
I finally got my shocks for my s411 after running for almost a month without them and of course 1 has a problem, it won't rebound at all. The others built as easy as pie. It almost feels as though the shaft is being restricted through the pre assembled part.
It actually rebounds very slightly 1-2 mm, I am thinking of trying to match the other side to it and running to see if it wears in?
#3045
I personally like the car way better with 0 rebound in the shocks! IMO full rebound is just force against the spring when the shock becomes more loaded... although I can see where changing from say 0 to 50% might make the springs feel the slightest bit stiffer without actually changing the spring rate, since spring rate changes can have a drastic effect on the car.
