Team Corally RDX Touring Car
#7861
how about the swollen shock bladders? would it be advisable to replace the shock bladders every other time you replace the oil?
#7862
I notice the swollen shock bladders too. They seem to shrink back down after a while. I usually rotate them out with some others that I have and when I go back to them, they're shrunk back down. Maybe I should be rebuilding the shocks with new bladders?
Thanks for the instructions Brian, I never really asked how to properly build shocks, and I struggled like hell getting them rebound right. It never occurred to me to push the shaft in and then use suction to hold the bladder on. It's too bad you can't bleed the shocks easily if you end up with too much, or an imbalanced amount of oil.
#7863
Use tamiya bladders, no more leaky.
#7865
#7866
Originally Posted by syndr0me
Tamiya bladders? Tamiya pistons? Maybe I should just switch to their shocks if they're so much better than Corally's. :-D
Greetings Ollie
#7867
A guy had had the blue TRF shocks on his RDX at the track...looked sweet if you had blue screws on as well. He said they ran very very smooth as well.
#7868
I have Tamiya 3 hole pistons (shimed), Tamiya Black TRF bladder with the red volume compensators, and Tamiya springs (shock collars flipped) and my shocks are buttery smooth
#7869
Greetings Ollie
#7870
really??
have you tired O-rings on the shock shafts?
#7871
really??
Thats it!
ANd it works really great!
Greetings Ollie
#7872
ARMS, ARMS ARMS any update on when more of the new arms will be in the USA. I'm down to my last old arm i really dont want to buy anymore.
#7873
#7875
have you guys tried o-rings over the bladders or do the foams work better on the corally shocks?
