TAMIYA M-06 Thread
#1891
#1894
Nice project!
Always thought about doing this with the Porsche 930 Tamiya shell, but never came to finish the project so far! If the wheels bring not the full offset, you could maybe use TL01 wishbones to gain track width...
I hope you post some updates next time,
Br,
Matthias
Br,
Matthias
#1896
Indoor asphalt, or used to. The track closed a month ago
#1898
#1899
great video,
hmm, ..since I have an M05, maybe i'll just have to pick up an M06 to see for myself.
I have tons of spare upgrades so can get it to a "pro" version / race ready easily.
#1901
Since you run and race an M05..you know what the most important functional upgrades are.
I have a lot of reading to do here on this thread,
Quick question though, ...I race F1's and maybe I shouldn't compare the M06 to an F1, but w/ both being a rear drive ...I tend to run my F1's diff loose. Is the same for the M06? I ask because I want to know if everyone runs the stock gearing or the "ball diff" ...w/ the M05 most get the ball diff (I think its a TA03 or something like that) and you tighten the heck out of it. You kind of mimic a TC car (fixed diff in front loose in rear). Yet w/ the M06 I am a little confused here.
thanks!
#1902
Yes, AND in looking at the M06 and M06 pro ...they run about $150 and $220 respectively. I looked at the manual and priced out the parts I'd need and it only comes to about $75 ...I have a ton of spare upgrades from my M05 that will all fit the M06 just fine. I think if I bought a kit i'd throw out everything but the chassis parts ...I have tons of ball bearings (I am particular about the brand I use), I'd use the big bore Tamiya shocks for the M class, Double Cardin axle joints, and I have all the TAmiya aluminum uprights. I can pick up a titanium screw set for about $30 ...So I may just put an M06 together w/o purchasing a kit. Being that I'll race this I will want to use very specific parts that aren't included in the kits.
thanks!
thanks!
#1903
The M06 is usually ran with a diff much looser than what you'd run in an M05. Also, DCJ is redundant on a RWD car, I'd just use normal universals.
Ah, good to know about the DCJ's !
#1904
The stock diff has very limited tuning. Good substitute is the spec R.
I use the M05 ball diff, it's lighter and much better design. I have always ran my ball diff tight and it seems to work for me, especially on carpet.
