kyosho inferno GT2 or ofna DM1
i'm not good explaining in details but maybe someone can help as well but some carbs come with 3 ventures of different sizes , the smaller the venture you save fuel but loose some power as well ...when i ran the force .28 i use 7 venture ...before you change the carb make sure it ok with GT spec rules..like said earlier i did this when i ran my jammin rtr
I would suggest getting the shim kit to add the 3 bearings to the clutch bell. This is the only problem I had with the car. I do here that people often break the hinge pin mount and change it to aluminum. I have not broken one yet but I don’t race to often but when I do I spend a lot of time hitting the walls.
Here is some videos dm-1 and gt2, im running dm-1 with ipanema warrior body and i really like it.
http://www.youtube.com/watch?v=gD_23...layer_embedded
#20
Can’t post links because I don’t have enough post but you can find the shim kit at nitrohouse.com under part number OFN10099 and the bearings under OFN35958 or where ever you can find a 5x8 bearing you can use 2 or 3 of these. The hinge pin mounts you can find on ybslowinc.com or kingheads.com Hope this helps.
#21
