Xs-ive R/c Design's Freedom Tc3 >
Old 05-16-2004, 08:43 PM
  #31
burbs's Avatar
personally i tried it on both sides... i did not notice a difference at all... there may be some scintific reason for putting it on one side or the other, but having tried both .. i cant say one works better then the other...
the warpspeed chassis is on the left also.. and i havent heard any of them guys complaining it hurt anything...
as far as i am concerend and have seen.. as long as u get all of your weight right on the corners.. there shouldnt be a counter balance issue,,
every shaft drive car and chassis is going to have some sort of tourqu steer.. with the way the motor is mounted it is hard to get rid of it.. all sedans have tourqe from the motor.. but on the others it torq's front to back....not side to side
burbs is offline
Old 05-22-2004, 04:14 PM
  #32
burbs's Avatar
bump
burbs is offline
Old 05-22-2004, 04:23 PM
  #33
it does not matter which way thje motor is mounted becuase the shaft will still turn in the oppostie direction which will part cancel the acting force of the motor.
however this will never work perfectly because the shft is off different diameter and lenght causing the rotational mass to be further spread.
rickylee53 is offline
Old 05-22-2004, 06:15 PM
  #34
The shaft does not spin in opposite direction from left side motor to right. If this was true the car would be going backward....
True R/C Racing is offline
Old 05-22-2004, 07:59 PM
  #35
Trader Rating: 3 (80%+)
the shaft spins the opposite direction of the motor. it doesn't matter if the motor is on the right or left.
Josh Hohnstein is offline
Old 05-22-2004, 11:10 PM
  #36
burbs's Avatar
yes josh is right// even if the motor is on the right or the left.. the armature still spins in the same direction... the only way the arm direction would change is if the motor was facing the front and not the rear...
burbs is offline
